Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-22-2006, 12:12 AM
sanddrag is on a distinguished road
Lasercutting/waterjet Cost - Disc with 6 holes
Not sure if I'll actually need this part or not but I might. I'd like to get a rough idea of how much it would cost me. Here's the part description:
Material 1/8" aluminum sheet.
Part:
Disc with 2.75" OD and a 1.2" ID hole (concentric)
Six (6) .190 holes spaced evenly around a 1.875 cirle (concentric with the disc)
Quantity 40 pieces
That's it, thanks.
You need not give me an actual quote that you have to stick by. I'm just looking for rough ideas of what it would cost because I really haven't a clue. If some other process would be more economical, I'm open to suggesstions.
Old 06-22-2006, 06:58 AM
Runner4404spd is on a distinguished road
if you need a real cost then you need to post a real print with dimensions and tolerances. you can cnc those discs as well as cut them on a waterjet. both of those options are probably cheaper than cutting with a laser.
Old 06-22-2006, 09:12 AM
mikeh78's Avatar
mikeh78 is on a distinguished road
probably $4-5 each cnc milled/drilled if tolerances are reasonable (6061 aluminum)
michael.hesse@hessemachine.com
www.hessemachine.com
Old 06-22-2006, 11:59 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Laser will be the least expensive even with only 40 parts
www.integratedmechanical.ca
Old 06-23-2006, 10:01 PM
fireman_1977 is on a distinguished road
Definatly laser. I could do it for about $3.00 each with our laser. Let me know if you are interested.
Old 06-24-2006, 11:55 PM
slatern44 is on a distinguished road
sanddrag,
I think I sent you a quote for this a couple of weeks ago and that time you had the material but just need the holes put in it. But if you need the hole parts done I can cnc machine them for $4.00 per part.
Thanks,
Neil
neil@slatermachine.com
Slater Machine and Tool
