Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-13-2006, 09:33 PM
sanddrag is on a distinguished road
Looking for small, simple, manual lathe work, any quantity
I have an 8x14 lathe that does not have anything lined up for the summer. I'm looking for anyone that needs small simple parts (up to 4" diameter 10" long) in any quantity. I'll give a good price since I have no expensive machines or shop space that I need to make payments on every month. Just trying to make a few extra bucks for the summer. I've been machining and doing 3D CAD design (primarily in the area of competition robotics) as a hobby for about 5 years.
I am also able to do some limited milling if the part requires that.
Please send me a private message or just post here if you are looking for someone to make your parts.
Old 07-31-2006, 08:43 PM
broncosis is on a distinguished road
I have a couple of ideas
hey you need to opcupie your lathe
I have a few paint ball gun parts I need made
they are delrin for the most part
I have made two now myself but I no linger have acceess to a lathe
they are about 5/8 of a inch in diamiter 4 holes 2 of which are on center in each end I'll see if I can find a pick or one
http://www.bobcat.ca/stuff/index.asp...r=pics/delrin/
thoose are of the first one I made which works but was a off center night mare
but the aluminum one is what I want to copy
there is lots of good easy to make parts for paint ball guns
from delrin I have been asked to make a trigger as well
but I think I'll task that by hand if one were to make a few
how much would it cost
Old 08-01-2006, 08:31 PM
HayTay's Avatar
HayTay is on a distinguished road
Arrow
Originally Posted by warpedmephisto
RFQ - Small lathe job 100 qty.
I need a RFQ on a simple pull pin to be done on a lathe, preferrably CNC. Pin dimensions are roughly 1/4" shaft by 1.25" long with a 1/2" head total length a little over 1.5" long. Have detailed CAD drawings on hand. Need a quantity of about 100 for the first run so CNC would make things quick. Part requires only 1 or 2 cutters and a part off blade. Made of 7075-T6 aluminum 1/2" x 3' extruded rod provided by me. I have a manual lathe - just don't want to crank out 100 of them by hand. Email to warped@htc.net or message me on here, or post in this thread. Thanks for looking!
Sanddrag,
I know it says "preferrably CNC", but with a good price, delivery and quality you could be awarded the job.
Original thread here: http://www.cnczone.com/forums/showthread.php?t=23031
I hope this helps!,
HayTay
HayTay
Don't be the one that stands in the way of your success!
