Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-09-2006, 01:12 PM
AustinT is on a distinguished road
RFW steel brackets
Looking for some quotes on 20 steel brackets cut out of 1" steel
the brackets are for a hinge. A steel 1.5" bar will pass through each bracket
Thank You
Austint
Old 05-10-2006, 11:54 AM
dfry is on a distinguished road
Material: 1018 CRS
CNC Milled Radius Drilled 1 9/16" Hole
$13.50 Ea. Plus $15.00 Shipping
Lead Time 1-2 Weeks
Devin Fry
F&F Machine Works
info@ffmachineworks.com
Originally Posted by AustinT
Thank You
Austint
Old 05-10-2006, 10:47 PM
Thanks everbody for the quotes. I was able to find a local shop that can get the brackets done right away. I am amazed at the number of quotes that I have recieved and definitely will be contacting some of you for future projects
Thanks again
Dan
