Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
  #13   Ban this user!
Old 04-18-2006, 02:22 PM
vacpress is on a distinguished road
Originally Posted by 302XRAM
"I think you should be able to get parts like those bumpers for around $5 each in quantiy of 5."
Your joking right? Thats $25.00 for the job. Put down the CRACK PIPE and step away from the keyboard!!!!!!!!!!!!!!
Sure, in a normal world that would be absurd.
However, in this world, which is inhabited with retired older gentlemen, young tinkerers, and the inbetween - all armed with CNC equipment, shops, and, generally, not alot going on - they may find it a pleasure to make ANY $ off their home machine..
Especially if it is as simple as milling a piece of aluminum 2D, and then pressing it into a really simple 'mold' or 'die' made of angle iron or something similar.
I am not smoking crack. I have heard stories of people here getting RFQ's for 'high accuracy titanium lathed part' filled for less than $50.
If you have a tiny MDF CNC machine that cost $500 to build, and it can just barely cut these 2D profiles in aluminum, but it can.. you might be willing to do this job as a 'paid learning experience'
so, scoff all you want. scoff away. exclamation points and all.(lots of them at that)
but you sir could very well be wrong.. and exclamatory..
  #14   Ban this user!
Old 04-18-2006, 02:24 PM
oh. the anodizing can be done with a car battery and plastic tub.. if im not mistaken...
obviousely though, the best choice would clearly be for him to goto a commercial shop...
but he is asking hobbiests..
  #15   Ban this user!
Old 04-19-2006, 06:54 AM
tjones's Avatar
tjones is on a distinguished road
I can get the parts laser cut cheap enough but throwing in design,deburring and coating for a small quantity may not be very cheap.
If you can at least do the design it would be a big plus on the quote.
Play around with this free Xpress software from Alibre and see if you can do a little solid model and send it my way.
http://www.alibre.com/products/
The software is easy to use and those parts probably could be desingned with nothing more than dial calipers.
  #16   Ban this user!
Old 05-04-2006, 09:23 PM
DrasticSports is on a distinguished road
Bumper Job Filled
I appreciate the quotes for this job. It has been my pleasure to see the work of some very talented machinists. I have accepted a bid for this job, which also turned into a couple of other projects as well.
It is my intention to build a product line with at least one machinist and so far the one I have selected is doing incredible work.
Sincerely,
www.DrasticSports.com
