Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-01-2006, 10:53 PM
rcazwillis is on a distinguished road
Triple Tree Cover
This is a new item. I will make 15 to start, but could be more batches. I am pricing this local also.
1. 16 gauge steel
2. Vendor supplies material
3. 15 pieces
4. Drawings attached.
5. Lead time should be 2-3 weeks. Quicker is better.
6. RFQ Ending is 3/8/06
7. Part will be chromed.
8. Price should be by unit with shipping to 76131 included.
The part requires two bends at the dashed lines. Direction does not matter as long as part is U shaped when finished.
Please ask questions. Please let me know if you need more detail dimensions on the drawing.
Rick,
RCAZParts, LLC
Old 03-02-2006, 07:19 PM
zcases's Avatar
zcases is on a distinguished road
I don't see any dashed lines when I import the DXF. Can you send a PDF of the drawing? And is it possible to send a STEP file of a solid model? Does your drawing account for the developed length of the bends? Can you allow a small radius on the inside corners?
Scott
zcases at frontiernet dot net
Old 03-02-2006, 09:22 PM
Can anyone else see the drawing correctly? It should look like the attached jpg. I have also attached a 3d drawing showing the shape after bends.
Old 03-06-2006, 12:14 PM
Huntersyv is on a distinguished road
I could see the first dxf. file you posted just fine and the dotted lines. I started putting a quote together for this job. Will you be doing the plating or should I include plating in the quote? Can I get an email address to send the quote to you direct?
Thanks, Hunter
Hunter Design & Manufacturing
E-mail: HunterDesignMan@aol.com
Old 03-06-2006, 12:29 PM
If you have reliable plating, please quote that separate. I have a plater I work with, but your pricing might be better.
email: rick@rcazparts.com
Thanks for the interest.
