Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-10-2006, 10:10 AM
kdoney is on a distinguished road
I need 2 7/16"-13 left-hand-threaded nuts
I need 2 each of 7/16"-13 left-hand-threaded nuts. I would prefer that they be .2" thick but I will take what I can get. I would use my lathe but that is what I am working on.
Old 02-10-2006, 11:17 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Never heard of a 7/16-13 thread..not even listed...are you sure??
7/16-14 yes..7/16-13 no...
MCmaster Carr has 7/16-14 stock..or probably any good fastener supply could get you some..
Old 02-10-2006, 01:42 PM
Well I ordered sloppy 7/16-14's from mcmaster and I'll see if they work but I verified it when I first bought the motor and then rechecked it after I looked for and couldn't find the tap. The distributor says that the thread on the end of the motor is indeed a 7/16-13 left hand thread.
Old 02-10-2006, 03:49 PM
Mcgyver is on a distinguished road
that's such an unusual thread.... I googled and found this...
http://www.surpluscenter.com/item.as...tname=electric
so somewhere in the supply chain someone does believe its 7/16 13....but it seems strange, have you mic'd it and checked it with a thread gage? Without that confirmation that it really is 7/16 13 i'd guess its either 7/16 14 or maybe the more common 1/2 13 thread and the motor guy is wrong
Old 02-10-2006, 07:27 PM
I tried to check but the total thread length is only .473 so I'm still guessing whether that last thread would be there or not. That is the motor I am talking about. It fit right into the old spot for my 9X20's chinese motor with no mods to either the gears or mounts. That was too hard to pass up.
Old 02-10-2006, 07:45 PM
thats why you need...
http://catalog.starrett.com/catalog/...ec&GroupID=256
or just buy a nut of each and see what fits or maybe it really is 7/16 13 and that's why its surplus
Old 02-11-2006, 08:56 AM
Thanks for all of the help gentlemen. It was a 7/16-13 and I found someone locally to cut some for me.
Old 02-11-2006, 11:56 AM
tjones's Avatar
tjones is on a distinguished road
Special but most likely it is a 11mm X 2 if it is a chinese motor.
Old 02-11-2006, 05:07 PM
The chinese motor was the one I was replacing. This one's from Mexico under license from the US. I'm betting the sloppy 7/16-14 will fit when it gets here. If it was a 11X2 then I would still be in the same situation since I couldn't find one of those either.
