Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-21-2006, 07:56 PM
mrbaseball is on a distinguished road
Milling work to square up pieces
I have some pieces of UHMW that I had another member cut and drill, however when I recieved them, they were not square by any means. I need someone that can mill the ends and sides. I need the pieces to be square and of equal sizes.
There are a total of 8 pieces that need to be milled.
Old 01-22-2006, 10:26 AM
ncmrfixit is on a distinguished road
Are all 8 pieces identical sizes now? What are the finished dimensions of the ends and sides, including overall thicknesses that you desire? How quickly do you need them?
Old 01-23-2006, 11:15 AM
The pieces were cut and drilled, but very sloppy. So the pieces that were cut in half to create two separate pieces are not square. There are four(4) blocks that are roughly 3 x 3 inches and are 1.5 inches thick. They were not cut square, so I need them all to be squared up. If you PM me your Phone # I can give you a call and discuss this. I am in no big rush to get these done, as long as they are done correctly
Old 01-23-2006, 02:00 PM
jmcd is on a distinguished road
Square up blocks
I can square up those blocks fo you.
Old 01-23-2006, 02:07 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Any Pictures?
