Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-14-2006, 11:48 AM
Gold Member
lerman is on a distinguished road
RFQ: Lathe or Screw Machine Job
15 mm tapered fitting in 360 brass, machined from .625 stock.
Initial qty 20. Estimated annual usage 1000 parts.
Please quote on qty 20, 100, 250, 500, 1000.
Located in Newtown, CT 06470.
Send email to lerman-quote3@se-ltd.com
I've added a revised figure with a flat milled on the 3/8 diameter for a set screw.
Thanks,
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Last edited by lerman; 01-23-2006 at 12:37 PM. Reason: Revised figure to add a flat.
Old 01-17-2006, 10:07 AM
Gold Member
RFQ: Additional quotes requested -- new parts
Initial qty 200 each. Estimated annual usage 2000 parts (each type).
Please quote on qty 200, 500, 1000, 2000.
Thanks,
Ken
Note: I've revised the OrificePlugShort -- dimensions have changed (been corrected) and the hole is no longer reamed. Also revised OrificeHolder to clarify (and fix) thru hole specification.
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Last edited by lerman; 01-17-2006 at 02:55 PM. Reason: Revised figure: OrificePlugShort and OrificeHolder
Old 01-22-2006, 09:57 AM
Gold Member
Thanks for Quoting
I've received several quotes on each part and will be contacting vendors this week to order parts.
I will also send email this week to those who responded but will not be selected at this time.
I will post two additional RFQs for small brass parts in the next few days.
Thanks again.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
Old 01-24-2006, 05:50 PM
Gold Member
RFQ: Closed -- Vendors Have Been Selected
Thanks to all of you who have prepared quotes. I recognize the effort that goes into it.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
