Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-16-2005, 05:55 PM
JavaDog's Avatar
JavaDog is on a distinguished road
RFQ - Simple Aluminum Work, Fast Turn-Around. - AWARDED -
Well, I decided to re-make the mounting for the rails on my CNC machine - so I can finally finish building the darn thing!
Interested in seeing what it might cost to have them made for me. Looking for a decent turn-around time (Shipping via FedEx should be included in the Quote) also.
Information:
- Quantity: 4
- Block is 1.50" x 2.00" x .50" Thick
- Material: Aluminum (6061 is fine)
- Shipped (FedEx Ground): Zip-Code 14221, New York.
- Tolerance: +/- .005" (reasonable, right?), +/- .001" on Center Bore.
- All Measurments on Drawings are in Inches
- Please Email Quotes to: JavaMoose AT Gmail DOT Com
Here is the part:
- IGES Format
- DWG (Export from Inventor)
- Inventor IPT
- Technical Drawing:
- Click for Larger-View -
- Pretty Render:
No, you don't need to polish it.
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
Old 11-16-2005, 08:29 PM
larry53 is on a distinguished road
block
How thick is it? It looks to be 1 inch. e-mail me at nec2@infionline.net and I will send a quote. Larry
Old 11-16-2005, 11:05 PM
DieGuy's Avatar
DieGuy is on a distinguished road
JavaDog clear you mailbox, dude!
Old 11-16-2005, 11:29 PM
Cold Fusion is on a distinguished road
You've got mail Javamoose!
Dieguy, how is your retrofit going? I guess good if you're bidding on this job
Proud owner of a Series II Bridgeport.
Old 11-17-2005, 01:28 AM
DieGuy's Avatar
Actually put on hold until the new building is up, I don't want to string and fling the 220 more than once, I will do this on my "little" mill.
Old 11-17-2005, 07:56 AM
JavaDog's Avatar
Heh, sorry - fills up quick!
Old 11-17-2005, 02:25 PM
JavaDog's Avatar
Job has been awarded.
Thanks to everyone that responded!
