| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I make aspheric lenses and my customer has just upped his order from 300 per month to 600- the only way I can meet this is to sub con the blank manufacturing (which I currently do in house). I therefore would be pleased if anyone could quote me for 600 off "Small Blanks"- flat both 'faces (roughly flat will do, I machine the surfaces anyway), diameter= 18mm, thickness= 4.5mm (tol on both these= +- 0.1mm). Material MR7 plastic (C of C required on material). There will be further requirements for 300- 600 per month. Many thanks in advance for your attention. [Edit] Have included a piccy- this is the "Small Blank" which I currently make in house, the part on the machine is the "Big Blank" which I skim then core- drill out to get the "Small Blanks" which obviously takes a lot of time! This is the Op that I want to sub- con.[/Edit] Last edited by ImanCarrot; 11-14-2005 at 04:22 AM. Reason: Including piccy |
Just send me the specs in 'English' measurements and I'll get you a quote put together. info@sandiegocnc.com Thanks! Patrick |
| Thanks, Metric: Diameter= 18mm, thickness= 4.5mm (tol on both these= +- 0.1mm). Material MR7 plastic (C of C required on material). Imperial: Diameter= 0.709", thickness= 0.177" (tol on both these= +-0.004") Material MR7 plastic (C of C required on material) Material has to be optical grade as I'm making aspheric lenses out of them. Many thanks in advance. Iain.
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
