Results 1 to 2 of 2
Thread: Tool Designer / Machinist
    Nov 2007
    catia.designer@yahoo.com Bill
    I am currently in the Lexington, KY area, but open to relocation, preferably south.
    TOOL DESIGNER / TECHNICIAN / MACHINIST
    OBJECTIVE:
    Seeking a position that will both utilize my strong experience as a Tool Designer and/or Machinist
    CERTIFICATIONS AND QUALIFICATIONS:
    • 10+ years tool, gage, jig & fixture design utilizing Catia V4, Catia V5, UGNX, AutoCAD, Autodesk Inventor, SolidWorks
    • 10+ years machining experience in tool, gage, jig & fixture work on mills, lathes, grinders
    • Proficient in reverse-engineering techniques
    • Experienced in use of Vectoron portable CMM using both touch probe and laser scanner
    • Hands-on experience in adjustment/repair/modification of jigs and checking fixtures
    • Named on US Patent #7040190 B2, Laminated Shift Fork Assembly
    WORK EXPERIENCE:
    Toyota Motor Engineering & Manufacturing -- Georgetown, KY 2006 - Present
    Quality Technician - Bodyweld
    • Support new vehicle launch -- dimensionally qualify weld tooling and jigs utilizing Vectoron portable CMM, comparing jig pins and datum block locations to automotive body IGES data
    • Adjust jigs as required based on laser scans of welded automotive sub-assemblies and CMM data
    • Repair IGES data as required using various CAD programs
    • Modify existing jig details utilizing mill/lathe/grinder
    • Fully document weld jig condition utilizing custom Excel formatted workbook
    • Ability to program and teach Nachi and Kawasaki weld robots
    Butler International -- West Lafayette, IN 2005 - 2006
    Tool Design Engineer
    • Utilize Catia V5 to design test fixtures for Sikorsky Aircraft
    • Update airframe and electrical drawings utilizing other CAD systems
    Keykert USA -- Webberville, MI 2004 - 2005
    • Design assembly jigs & fixtures for manual and palletized automation assembly of automotive locking system modules, utilizing Catia V4, Catia V5, Unigraphics NX, Autodesk Inventor, and AutoCAD
    • Support manufacturing engineering in identifying and troubleshooting production assembly issues
    • Design and implement production process improvements
    AMSEA, Inc. -- Fenton, MI 1995 - 2004
    Tool Designer
    • Design fineblanking dies and related press tooling components for small stampings, utilizing SolidWorks, Autodesk Inventor, and AutoCAD
    • Design and build of special gages, jigs, fixtures, and special tools
    • Program CNC wire EDM cut paths utilizing Esprit and AutoCAD
    • Reverse engineering of die tooling components
    • Develop and implement process improvements
    • Support customers with product design assistance
    CAD system administration and secondary network support
    Novi Industries -- Novi, MI 1990 - 1994
    Machinist
    • Machining of various automation line details utilizing mill, lathe, and surface grinder
    • Prototype tooling development and fabrication, overseen by project engineers
    • Create machining fixtures on-the-fly, as well as designed on AutoCAD
    • Fabrication of scale-model prototype production equipment
    • Design of modifications to existing automotive production equipment utilizing AutoCAD
    Dependable Gage & Tool Co. -- Oak Park, MI 1986 - 1990
    Machinist
    • Machining of various automotive and aerospace gage details line details utilizing Bridgeport mill
    GTE Valeron, Digital Techniques Div. -- Troy, MI 1984 - 1986
    Machinist
    • Machining of details for air and manual gages, utilizing Bridgeport mill (manual and CNC), Mazak machining center, and Mazak turning center
    CLEARR Industries, Inc. -- Warren, MI 1981 - 1984
    Machinist
    • Machining of automation details for automotive welding and assembly lines, utilizing CNC mill
    Weldmation, Inc. -- Madison Heights, MI 1978 - 1981
    Machinist
    • Machining of automation details for automotive and appliance weld lines, utilizing Bridgeport mill
    CHECK OUT MY 7X10 CNC LATHE CONVERSION HERE
    "Shouldn't YOUR Tool Designer have strong machining background?"
    KEYWORDS:
    AutoCAD, Inventor, SolidWorks, Catia, Unigraphics, Esprit, CAD, Tooling Design, Tool Designer, Jig, Fixture, Reverse Engineering, Process Improvement, Continuous Improvement, Fineblank, Fineblanking, Vectron, Vectorarm, Automotive Performance, R&D, Prototype, Faro, Laser scan, Wire EDM
    Beer is always good. If you can't figure it out on beer, it's not worthwhile. - knudsen
    Oct 2010
    Are you willing to relocate to NY?
    Dane Brecher Plastic-Craft Products
    (Phone: 1-800-627-3010) dane@plastic-craft.com
  1. Looking For A Job- Up For Hire! CNC Machinist, CAD Drafter, CAD Designer
    By Maile Richie in forum Employment Opportunity
    Last Post: 01-19-2009, 09:22 AM
