Results 1 to 4 of 4
Thread: JOB OPENINGS Tool Designers
    Aug 2011
    U.S.
    I currently have 10 openings for Tool Designers at the Rock Island Arsenal in Rock Island, Illinois.
    The positions are through my company HRU Technical Resources. We are the sole staffing agency for these positions as well as many others at the arsenal.
    The Positions have a government regulated pay rate of $30.26 per hour for first shift + benefits. Benefits include paid holidays (12) and vacation days (10) per year.
    Description of Work
    Create original designs of tooling components for use in a metal working production factory environment. Mill, Lathe, weld, and grinding fixtures: drill jigs, cutting tools, gauges, ect.
    Trouble shoot various manufacturing problems.
    Required Background:
    Unigraphics (UG) NX5 or newer
    Design experience (machining fixture, weld fixtures, die design)
    Modeling
    Please PM me or email your resume to vankuiken.brent@hru-tech.com
    Thanks,
    Brent
    Jan 2006
    Good luck with your search it was nice talking to you a few weeks ago.
    Aug 2011
    U.S.
    Job discription
    Tool Designer
    The Rock Island Arsenal is located on Arsenal Island, originally known as Rock Island, on the Mississippi River between Davenport, Iowa, and Rock Island, Illinois.
    The Tool Designer position is a contract position through my organization HRU Technical Resources. HRU Technical Resources is a contingent staffing firm, which specializes in engineering, IT and technically related placements across multiple industries. HRU is currently the sole staffing agency for this and many other positions at the arsenal. Contract positions at the arsenal through HRU are benefits eligible and are open ended long term unless otherwise specified.
    The Tool Designer position has a government regulated pay rate of $30.26 per hour for first shift. If assigned to an off shift or shift other than first a shift premium will be added to your hourly wage while working that shift.
    Description of Work
    The tool designer designs single- or multiple-edged machine cutting tools, such as broaches, milling-machine cutters, and drills, and related jigs, dies, and fixtures.
    Responsibilities:
    • Create original designs of tooling components for use in a metal working production factory environment. Mill, Lathe, weld, and grinding fixtures: drill jigs, cutting tools, gauges, ect.
    • Troubleshoot various manufacturing problems involving process, method, tooling, or programming and coordinate the solution with the appropriate branches.
    • Compile budgetary estimates and prepare acquisition forms for BOM items of the designed tool, or a piece of tooling.
    • Learn then utilize various computer software and systems including, but not limited to: Microsoft Office, CAPP, FACS, and TAMM’s.
    Required Experience:
    • 2+ years Design experience using Unigraphics (UG) NX5 or newer
    • 2+ years experience designing machining, weld, or NC fixtures
    • Experience designing dies, jigs, and molds
    • Trouble shooting designs
    • Modeling
    Qualifications:
    • Eligible for Security Clearance
    • Open to work any shift
    • Available for occasional overtime
    • Open to occasional weekend or holiday work
    Aug 2012
    india
    I'm sorry to say this but there're very few direct employer contacts, if any, on mainland job adverts. many adverts ask for loads of personal info, passport copies, credentials.
    dougleschan.com
  1. ACE Designers LT20 Lathe Help!
    By OCMW in forum General Metal Working Machines
    Last Post: 07-13-2011, 06:31 PM
  2. Need advice from commercial designers
    By originator in forum Glass, Plastic and Stone
    Last Post: 06-07-2009, 05:52 PM
  3. Makers/designers of Z-axis for Plasma?
    By Knut in forum General Waterjet
    Last Post: 10-19-2006, 07:30 PM
  4. power supply designers: help?
    By owhite in forum General Electronics Discussion
    Last Post: 02-10-2004, 05:52 PM
