10-09-2005, 08:10 PM
RFQ: 3.81" big nut. Lathe or mill w/ fly cutter | | Well once again, my custom part needs are beyond the abilities of my toys. See attached DXF - I've even done some figuring of tool paths for you on hidden layers and written some g-code for doing this on a mill. (see the txt file)
The drawing is to scale, so any dimensions I've missed can be added.
Parts are made from .75" thick aluminum blocks (or cylinders) 4" in diameter for the part.
I will need 4 of these. Timing is not critical or anything, just some time this month. |
