Diversified Industrial Staffing - Machining Fixture Designer w/machining background
Job Location:
City: Walled Lake
State/Province: Michigan
Country: United States
Job Information:
Ref Code: Machining Fixture Designer w/machining background
Employee Type: Apprentice
Salary: From $ 22.00 To $ 24.00 per hour
Walled Lake based manufacturer seeks experienced Machining Fixture Designer. Must be well versed in the Casting Process, looking for someone with a machining background. It is important to understand HOW you make a part to properly design fixtures and help with quoting. Will need to be able to do Design Work Holding Fixtures for Vertical and Horizontal Machining Centers, as well as Horizontal Boring Mills. All candidates must be able to pass a drug test and felony background check.
Send resume to: employment@diversifiedindustrialstaffing.com
Requirements:
Education Required: High School
Experience Required: 3-6 years
Travel Required: None
