Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-24-2011, 11:53 AM
RBoslow is on a distinguished road
Job Opportunity
Machinist or Machine Operators for the Raleigh, NC plant
One to three years, or more, of experience in set-up and operation of CNC and Manual Lathe and Milling Machines. Machine parts and castings to close tolerances is essential. Demonstrated ability in the use of micrometers, vernier calipers, overhead crane and hand tools. Machines used in shop: Kearney Treker, Mori Seiki, Olofson, Schiess, Mitsibutsi, Cincinnati, Mazak, Motch and Travisan. Work from layouts and dimensions on drawings, using indicators, height gauges, etc. Loads, aligns, sets-up and operates machines per drawing instructions. Unloads, checks for quality. Debur casting/part, as required. Maintain quality and quantity. Maintain clean and orderly work area. Follow all safety procedures. Maintains records of production (route cards).
Requirements: Use of shop arithmetic. Ability to read blueprints. Knowledge of machining methods, cutting tools, cutting qualities of metals and overall manufacturing experience. One to three years or more of machining experience or graduate of machining program. Candidate must be open to working 2nd or 3rd shift (there is shift differential compensation). Shift assignment will be determined by machine openings and skill set. There is some relocation assistance available.
Please do not apply if you are unable to work an off shift. First shift is not available !
Shift assignment will be determined at the interview.
We are sorry but we do not have opening for Drill Press Operators, Press Brake Operators or Tool and Die Makers.
Please apply on line at the link below or cut and paste it into your browser.
http://jobs.brassring.com/1033/ASP/T...75&Areq=9673BR
job opportunity mishikwest Employment Opportunity 1 01-08-2008 11:22 AM
Fantastic Opportunity! JacobCase Employment Opportunity 0 10-11-2007 08:35 AM
Mass-cnc Job Opportunity mkmk123 Employment Opportunity 2 09-18-2007 05:58 PM
Employment Opportunity dalworth Employment Opportunity 0 09-07-2007 01:50 PM
CNC Opportunity in Baltimore, MD CNC guy Employment Opportunity 0 05-14-2007 04:26 PM
