Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-14-2011, 01:18 PM
RBoslow is on a distinguished road
Machinist - Machine Operator
Machinist or Machine Operators for the Raleigh, NC plant
One to three years, or more, of experience in set-up and operation of CNC and Manual Lathe and Milling Machines.* Machine parts and castings to close tolerances is essential. Demonstrated ability in the use of micrometers, vernier calipers, overhead crane and hand tools. Machines used in shop: Kearney Treker, Mori Seiki, Olofson, Schiess, Mitsibutsi, Cincinnati, Mazak, Motch and Travisan. Work from layouts and*dimensions on drawings, using indicators, height gauges, etc. Loads, aligns, sets-up and operates machines per drawing instructions. Unloads, checks for quality. Debur casting/part, as required. *Maintain quality and quantity. Maintain clean and orderly work area. Follow all safety procedures. Maintains records of production (route cards).
Requirements: Use of shop arithmetic. Ability to read blueprints. Knowledge of machining methods, cutting tools, cutting qualities of metals and overall manufacturing experience.* One to three years or more of machining experience or graduate of machining program. Candidate must be open to working 2nd or 3rd shift (there is shift differential compensation).* Shift assignment will be determined by machine*openings and skill set. There is some relocation assistance available.
Please do not apply if you are unable to work an*off shift.* First shift is not available !*
Shift assignment will be determined at the interview.*
We are sorry but we do not have opening for Drill Press Operators, Press Brake Operators or*Tool and Die Makers.
Click or cut and past the below link to apply on line. Thank You
http://jobs.brassring.com/1033/ASP/T...75&Areq=9672BR
Job Opening Machinist/CNC Operator/CNC set-up Scott442 Employment Opportunity 1 01-30-2009 05:33 AM
Job Opening Denver Colorado! Machinist/machine Tool Operator csmith Machinist Feedback 0 12-31-2008 03:07 PM
Job Opening CNC/Manual Machinist/Operator Needed!! bugzpulverizer Employment Opportunity 0 07-10-2008 03:09 PM
5-axis CNC Machinist Programmer Operator joshiroc Employment Opportunity 0 02-16-2007 06:50 PM
Machinist - CNC Setup & Operator in FLA sundara Employment Opportunity 0 12-24-2004 09:35 AM
