Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-04-2011, 09:58 PM
Lee in Texas is on a distinguished road
1 Sub Plate 216 holes
I've got a piece of 6061 that I want turned into a sub plate. It's 1" x 8" x 27". It needs 216 holes, 1/4"x20tpi, spaced 1" apart. The holes need to go all the way through. I don't have a drawing yet but if you need one, let me know.
Thanks, Lee
Old 03-05-2011, 12:30 AM
abcmojave is on a distinguished road
information request
Hi Lee,
I take it that the holes start .5 inches in from the edges? Square pattern or other? Tollerances?
Old 03-05-2011, 01:28 AM
Originally Posted by abcmojave View Post
Hi Lee,
ABC-
Yes, the holes start .5" from the edges. The holes are in a square pattern. This will look like a sub plate but be used as the base plate for a model car/motorcycle frame jig. I'll make my own brackets for keeping everything lined up. The holes need to be precisely spaced, but if they start .532" from the edge on one side, it really won't matter. I can send a photo of a smaller one that I have. It was made for me several years ago as a sub plate for my Sherline mill. It works great for that, but at 9"x5", not so great for 1/8 scale car chassis or 1/6 motorcycle frames.
Old 03-05-2011, 01:41 AM
information
Ok Lee,
It sounds like standard .005 tollerances would be ok. I know you need the holes full depth. You need them threaded full depth?
Old 03-05-2011, 01:48 AM
If they're threaded most of the way, that would be fine. The main reason I want them all the way through is to be able to clean them.
Old 03-05-2011, 01:57 AM
Ready to quote
Lee,
Quote in Private Message.
ABC
Old 03-05-2011, 02:06 AM
Got it. Sold! thanks.
Plate Beveling round holes? Plasma or Oxy/fuel WSS CNC Plasma and Waterjet Machines 4 01-07-2011 12:55 AM
How to cut say 3" holes in 1/2 aluminum plate??? wrechin2 General Metalwork Discussion 14 01-25-2009 10:09 AM
Any tips for designing a fixture plate / tooling plate? thackman Benchtop Machines 9 12-19-2008 11:26 AM
1" holes in 1/4" 304 SS plate. Loading General Metalwork Discussion 5 10-25-2007 07:33 PM
Cutting Large Diameter Holes in Aluminum Plate barkster General Metal Working Machines 18 04-07-2004 05:44 AM
