Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 03-01-2011, 10:08 AM
DLProcessor is on a distinguished road
RFQ: Modified Optical lens adapter
Hello,
I am looking for a quote for this part that I want made. I only need one piece. Part should be made of aluminum (6061 or 6063) and needs to have a black anodized coating. I need it for a lighting application and need to minimize light reflections, hence the coating. I have included the drawings in a pdf file, some renders, and an STL file for 3D viewing purposes. The drawings should be self-explanatory but if anyone needs any clarification let me know.
Note: The x2 6mm-diameter outer screw hole inlets are optional and can be eliminated if it can significantly reduce costs. Thank you for your time.
ID:	127773   Click image for larger version
Old 03-01-2011, 03:10 PM
kdoney is on a distinguished road
When do you need it?
Old 03-01-2011, 03:37 PM
Maximum 2-3 weeks. But the sooner the better.
Old 03-01-2011, 09:35 PM
mrquacker is on a distinguished road
If you need a truly black surface, check out: Pioneer Metal Finishing - Optical Black
DUAL FOCUS LENS (bifocal lens) bibi Laser Engraving & Cutting Machines 5 03-17-2009 05:03 PM
Do I need a Focusing Lens? Clockwork Laser Engraving & Cutting Machines 7 02-13-2009 06:29 AM
Problem- LENS SIZES SHADOW042 Laser Engraving & Cutting Machines 0 08-05-2008 09:29 PM
Looking for some Help Optic Lens tklock Laser Engraving & Cutting Machines 9 03-27-2008 05:39 PM
Where to buy lens? medved Mechanical Calculations/Engineering Design 5 12-30-2005 02:49 AM
