Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-23-2011, 12:57 PM
3PMA is on a distinguished road
Post MultiAxis Programmer required
3 Points Machining and Aerospace is currently seeking a MultiAxis Programmer
The successful candidate will be responsible for process planning, generating fixtures designs and create simultaneous 5 axis CNC programs, and set-up CNC equipment. Candidates will be required to provide evidence of experience in programming with a “proof” (i.e. screenshots, photos and sample parts that were developed and or designed).
• Machinist first and foremost, with strong computer skills, a deep understanding CAD/CAM software installation, network troubleshooting and web based support tools
• Able to ask for help from your co-workers and suppliers when needed
• Strong CAD skills (surfaces, solids, healing and fixing of CAD data, generation of shop drawings including GD&T)
• Strong understanding of multiaxis programming, RTCP programming, tool life management, laser pre-setters, and the
• Able to correctly identify, source, and utilize the correct tool holders, grades, and workholding fixtures
• Equally able to work on the floor as well as work on a CAD/CAM workstation
• High level CNC Professional able to take on the entire scope of designing, planning, programming and machining of tight tolerance aerospace parts (distinctly separate from a machine operator or basic 2D CNC Programmer)
dmcdonald@3pointsaviation.com
Tags
multi-axis
Job Opening Multiaxis job near Raleigh, NC fpworks Employment Opportunity 0 09-25-2010 12:33 PM
Job Opening Mill/turn operator-programmer required Dan B Employment Opportunity 0 08-11-2010 05:46 AM
Newbie- 4th / multiaxis output pinguS SolidCam 27 02-01-2010 04:04 AM
CNC programmer required in UAE hai2basith UG NX 1 01-11-2010 10:02 PM
Multiaxis gurus out there? WingNutz Mastercam 9 02-05-2009 04:33 PM
