Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-21-2011, 07:44 PM
LEINC is on a distinguished road
Programmer/Operator Indianapolis, IN
We are looking for an experienced CNC programmer/operator that can go from drawing/model to finished part with little or no guidance.
Basic 4 Axis mill experience is a must.
Must have experience with CAD/CAM applications. Surfcam experience is a BIG plus, as it is the programming environment we use.
Must be proficient in CNC tooling. You must know how to determine what tooling you will need to complete a job.
Experience on both mills, and lathes is a plus.
The majority of the work is prototype, proof of concept, and some tooling to support our production department, with the occasional small production run.
We have machines from various builders, all with Fanuc controls.
Manual machining experience is a plus, and preferred.
The ideal candidate will have experience in job shops, small prototyping shops, tool rooms, etc. We are NOT looking for the type of production "machinist" found in todays factories.
This position is 1st shift, 6:00am to 4pm Mon - Thurs. Must be able to stand for a full 10 hr shift and lift 30 lbs repetitively. Must have long term dependable work history and be able to pass a drug screen. HS Diploma or GED required.
This is a temp-to-hire position. Your interview, and subsequent employment will be handled by our recruiter.
If you are interested, please PM me for more info, or follow the link below for contact information.
APPLY HERE
Tags
cnc, job, surfcam
Job Opening CNC Lathe setup & programmer needed near Indianapolis, IN 6thAxis Employment Opportunity 1 03-29-2012 07:16 PM
CNC Operator Position Availalbe in Indianapolis, Indiana! dunhillwest Teachers Hang out 0 10-07-2008 10:54 AM
CNC Operator/Programmer norwood Employment Opportunity 5 10-06-2008 09:36 AM
CNC PROGRAMMER/OPERATOR Melissa Lawson Employment Opportunity 0 01-09-2008 09:40 AM
CNC Programmer, Set UP, Operator lbi17 Employment Opportunity 2 11-16-2007 01:52 PM
