Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 02-21-2011, 04:18 PM
wilstyx's Avatar
wilstyx is on a distinguished road
Mopar Madness !
Looking to get 6 parts made of either aluminum or stainless. What I need is a tapered pentastar ( pentagon ) tapering from (inscribed in a 1" circle to inscribed in a 5/8" circle ) 3" long. Can have 1/4" holes in each end. I made a jig that makes the thing perfect out of wood but tried cutting the aluminum and it was a nightmare. Seems like it would be simple enough if I had the right type of mill. What these are going to be is the Turn signal lever knob, the oil dipstick and the transmission dipstick handles and the tilt knob ( and 2 spares just in case) for my 1932 Plymouth street rod. I can do the machining on my lathe to finish them off. I can furnish an ACAD drawing or a wood model. Thanx in advance !
Old 02-22-2011, 10:07 AM
a1cadcam is on a distinguished road
is this what you are looking for?
1" inscribe to 5/8 inscribed... (measured to the points)
i will buff the 5/8 edges...
2 per length... one on each end
you can part off if you wish or i can do it...
we could put 0.05" rads along the long edges or around the 5/8 end...
or bigger/smaller
if you are interested... email me...
phil@tddinc.com
we do a lot of custom Hot Rod and 4x4/buggy parts here.
ID:	127140   Click image for larger version
Need Help!- Mach3 and MPG2 madness. cjdavis618 Mach Software (ArtSoft software) 9 07-25-2010 11:58 AM
Gekko 320 & Z-Axis servo Madness need help :( ! 1.5 year battle Rich05 Gecko Drives 12 08-06-2009 09:19 AM
Khalid's Madness: Break Through in speed increase in 3D contouring (DIY) Khalid CNC Wood Router Project Log 11 12-17-2008 06:51 AM
CNC Madness (Restoring old parts) samualt CNCzone Club House 2 06-19-2004 09:04 PM
