Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-27-2011, 07:50 PM
yoopertool is on a distinguished road
Plastic mill/router RFQ
I have a few parts I would like to have quoted. I typically make these myself, but am pretty busy right now, so if I can find the right shop and price, I wouldnt mind out-sourcing these this time. I have attached a print (rough) the dimensions on hole location and diameter are ±.005 and width tolerances are ±.010. I will provide a better print if I end up sending it out. I would like a quote for 64 of these made from white HDPE. You would provide the material. I would need the parts within 2 weeks aro.
All holes and edges need to be chamfered. If you arent sure that you could make them to print and on time please do not respond. Please send quotes to lakermanf@gmail.com. Shops in southern Minnesota prefered. Thanks
Router for Plastic Disks whiskey oscar Want To Buy...Need help! 5 10-06-2010 12:15 AM
What type of end mill is used for plastic? replicapro General Metalwork Discussion 10 07-21-2010 10:29 AM
Need Help!- Choosing CNC Router for Plastic Fab JohnClayton Want To Buy...Need help! 0 03-13-2010 05:40 AM
Problem- Material Recommendation, Plastic for CNC Router lclore General Material Machining Solutions 4 04-11-2009 03:20 PM
The problem with router speeds and plastic. dbtoutfit General Material Machining Solutions 13 05-08-2007 07:09 AM
