Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-26-2011, 10:34 PM
ahaidet is on a distinguished road
RFQ small aluminum pieces both mill and water/laser jet parts
I need to have the following parts made for an assembly that I am selling. A friend machined these for me previously but has since got out of the business.
The numbering (name) of the parts is based on their order in the assembly.
Part #3
I need a quantity of 4 to complete the assemblies I have started. Any aluminum alloy will work. We used 5/8" x 1.5" bar before.
The image shows two 1/4-20 tapped holes on the front, these are duplicated in the rear but are not visible.
Part #4 is a very simple water jet or laser jet part it could also be milled as well.
I also need a quantity of 4 of these to finish the current assemblies.
1/4" aluminum plate any alloy will work.
Parts need to be free from burrs and need to have finished edges all the way around (no rough saw cut edges; would think this would have been obvious but from previous work completed by a machinist on here it may not be). The edges may be the raw aluminum bar were applicable as long as its smooth.
I can provide IGES or STEP files on request. Let me know if there are any other questions.
These parts are part of a larger assembly as I mentioned before this is a newer design than ones I have sold previously. If they work and sell as well as I hope they do then this will likely turn into a reoccurring order.
You may quote either part individually or combine them together. I would prefer to deal with one supplier/machinist if possible. Please include shipping to 44224.
Thanks.
Old 01-27-2011, 05:31 PM
FUBAR62172 is on a distinguished road
pm sent
thanks
Old 02-03-2011, 09:42 PM
newarkprecision is on a distinguished road
I see that you are from Ohio. I am a shop here in Newark Ohio interested in quoting your work for you and develop a working relationship. Visit my website www.newarkprecision.com
Old 02-04-2011, 08:05 AM
This job has been awarded thanks for all who bidded on this.
Need A Quote- RFQ for 30 - 60 thousand small aluminum pieces. porterico Employment Opportunity 20 01-13-2011 07:35 AM
Need A Quote- Small Aluminum Parts Mill Work ahaidet Employment Opportunity 4 10-27-2010 10:42 PM
Need A Quote- RFQ Aluminum parts for small CNC mill southernexplore Employment Opportunity 6 10-02-2009 11:08 AM
Need A Quote- Small Aluminum rectangle pieces TMaster Employment Opportunity 6 09-29-2008 05:49 PM
RFQ: Mill and Laser/WJ Work, 2 Aluminum Parts kend Employment Opportunity 2 04-30-2007 05:01 PM
