Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-15-2011, 08:15 PM
Enraged is on a distinguished road
RFQ: Holddown bracket
Need a quote for an aluminum bracket.
Material is aluminum, it is a cosmetic bracket, so 6061 or similar should be fine. I've attached 2 IGES files, one with a chamfer and one without, I'd like pricing for each version. The chamfer also does not have to be as modeled, if you think you can make it better/cheaper a different way, let me know. The center groove can be done with a ball mill, probably a 3/4", again for cosmetics.
I'd like pricing for 2 and 4 prototype parts, as well as batches of 10, 20, 30, 40, and 50, possibly more in the future. Machined/deburred finish, but if you have anodizing available let me know what the cost would be per unit.
If you have questions, feel free to ask. I'd like to get the parts within a month of ordering, but the schedule is flexible right now.
FS: Complete Z-Axis Assembly with THK RSR15WM slide, leadscrew, stepper mount. PM for more info.
Old 01-15-2011, 11:06 PM
tmreitz's Avatar
tmreitz is on a distinguished road
quote nm radiator bracket
PM Sent
Tim Reitz, Sky King Machining LLC
sales@skykingmachining.com
Old 01-15-2011, 11:53 PM
Matt@RFR is on a distinguished road
Do you realize that, according to your title block, you have +/-.001" all over this thing? Do you really want somebody to check a counterbore and clearance hole with anything other than calipers?
Old 01-16-2011, 02:26 PM
i just threw it onto a stock title block, obviously for a cosmetic upgrade part like this those tolerances aren't needed I apologize if those scared anyone off.
Old 01-18-2011, 03:49 PM
FUBAR62172 is on a distinguished road
pm sent
Old 01-18-2011, 09:03 PM
brmachineshop is on a distinguished road
pm sent, thanks
pm sent, thanks
Old 01-19-2011, 10:36 AM
Job awarded, thanks for everyones response.
Vacuum Holddown for corian/lithos... Arbo Work Fixtures and Hold-Down Solutions 2 09-03-2010 10:26 PM
Newbie- Advice about machine and used vacuum pump for holddown Ping DIY-CNC Router Table Machines 1 03-14-2009 06:12 PM
HobbyCNC Router - Holddown question buckey29 Open Source CNC Machine Designs 3 10-10-2007 06:22 AM
My simple holddown clamp P.Passuello Work Fixtures and Hold-Down Solutions 14 05-06-2007 07:20 AM
Table Enlargement/Part Holddown kellogs72 Benchtop Machines 2 12-18-2004 08:07 PM
