Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 01-13-2011, 01:19 AM
cgwiita is on a distinguished road
Two ~85mmx12mm foam parts
I'd like to get some quotes on some lightweight foam parts. They have some internal cavities, but overall, tolerances aren't critical. We're flexible on both materials and production method, we just would like to have a density close to EPS/styrofoam. Just one of each now for prototyping, although we will eventually require tens of thousands, if you have foam molding capabilities. Images below--send me a PM with an email address and I can send native Solidworks or any other format.
ID:	123794   Click image for larger version
ID:	123795   Click image for larger version
ID:	123796   Click image for larger version
3D topographical map routered out of foam foam 3Dmap CNC Wire Foam Cutter Machines 2 08-25-2007 07:55 PM
I'm looking for Info on CNC Foam for mold cutting for car parts ? Calico CNC Wire Foam Cutter Machines 5 08-18-2007 06:55 AM
Using printers parts to build foam cutter. Rypper CNC Wire Foam Cutter Machines 2 04-30-2007 12:14 PM
Foam cut parts to cast. venomx999 Casting Metals 0 02-14-2007 11:16 PM
I'm looking for someone to cut and coat custom foam parts decor designer Machinist Feedback 4 08-21-2006 05:44 PM
