| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I need some parts made from red oak boards. The parts are made with a simple profile cut by a 1/8" bit. The wood I am using is sustainably harvested. Because I will be supplying the wood I need the quote to only include cutting the parts and boxing them up. They need to be free from any tabs or large burrs (ready to be sanded). To start, please give me a quote for the attached parts. I need: 500 "Truck MB.dxf" made from 3/4"(after planing) boards and 1000 "Truck PN.dxf" made from 1/2" boards I have a preferred grain direction for each of these. I have other parts I need done that are similar in scope. Let me know if you have any questions. Thanks, Hyrum Fairbanks PE |
| You do realize that you have square inside corners and a bunch of radii that are less than 1/8" right? Are you saying that whatever a 1/8” bit can cut is OK for the sake of what you want? This might be a laser job but, at those thicknesses, I don't know if that would work or not.
__________________ Greg |
| Yeah, I realize there are sharp corners that can't be cut out with a 1/8" bit. I specified that I wanted a 1/8 bit because that's the level of detail I want. I do not want these to be laser cut. I already made a few of these on a bench top milling machine so I know what they look like cut with a 1/8" bit. I'm just not set up to make thousands of them. Thanks, Hyrum
| 4"+ x 6'+, Minimum Yield 83 1/3% Northern Red Oak I look forward to reviewing your quote. Thanks, Hyrum |
| You also mentioned a preferred grain direction. That will affect how many you can nest to a single board. If the grain direction is parallel to the ground on your models, my guesstimate is you'd get 12 parts per board. Does that sound right?
| tired a wood called bow wood or orange osage | woodman08 | Gorilla CNC Machines | 2 | 01-17-2010 08:37 AM |
| Newbie- cutin all parts in one wood sheet. | Dingin | CamWorks | 2 | 12-02-2009 01:46 PM |
| Where can I find Good CNC Wood Cutting machine for Car parts size ? | Calico | DIY-CNC Router Table Machines | 3 | 02-27-2005 11:36 PM |
| Where can I buy 4-5 Axis Wood CNC for making Car Parts ?? | Calico | Commercial CNC Wood Routers | 0 | 02-27-2005 07:21 PM |
