| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I'm sorry I do not have a blueprint. I do have a picture with measurements, and if interested I can also mail a few pieces of the part to you for inspection. The part is used to (crimp) hold together 2 ends of 35-50lb test fishing line. Quantity Desired - Minimum 20 thousand, Please quote for 20k pieces increments up to 100k pieces, so 20k,40k,60k,80k, 100k pieces. Delivery- Oakland, CA The parts in the picture are actually slightly higher quality than we need. Will be happy to send a few pieces of the part for inspection. |
| As an extrusion, these pieces would be maybe about .1 gram each. It would take 10K pieces of the extrusion to make 1 Kg. As far as I know, there is usually a 1000 lb (~450 Kg) minimum for custom extrusions. Thus it would take 4.5 million parts to meet the minimum for an extrusion. Sure would make the job quick and easy though. |
We are still looking for premade crimp beads that will do the job, they are incredibly inexpensive, the ones in the picture are actually not from our manufacturering run in the past, but probably more like a custom extrusion job for fishing tackle suppliers. Those pieces cost off the shelf about $3 for 20 or 25 pieces. We found someone last time to do them for a few cents each, which made it worth it to us. I'm going to send samples to a couple of people on the board, and also check with a local machining outfit reccomended by one of you. I appreciate the consideration. One person quoted a price high enough we could have bought some nice machines ourself! That was a bit funny, but not surprising. I would just love to find someone in the US especially that can do this without breaking our bank! Thanks again. |
| There are some extrusion outfits down in texas that will do 40 ish lb minimums through small, high precision extruders. I think they had a 2 inch circle size, and spec precision was pretty remarkable. The last time I looked into it, a die for that would be around $ 1,000 - 1,500, plus the metal cost. Their metal cost was a bit higher (double) than the cost from a full size extruder, but of course the run size was smaller too. The only concern I would have is if the cut process would squish the part. No, I am not bidding, just watching. I hope it goes to a North America based outfit as well.
__________________ Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2 |
#10
| by CNC, arround $1 each,but I will try to find some other way to decrease the price. do you know the name of this part?Is it possible change material from aluminum to some powder metallurgy material? Regards! Shen.Ji C-Hi-Tech Inc. China |
#12
| Why are you not just contacting a company that makes these? In the end, the crimps you use will have to be mated to a proper crimping tool. In industrial quantities, that is really the only way to go. What are you crimping them with now? Industrial crimpers come as matched pairs with specific dies matching a series of proper crimp barrels. They should also offer air-driven tools as well as hand tools to consistently set them. If I had 20,000 crimps to do, I'd darn-well make sure I had an ergonomically friendly tool to set them and if your profit margin is as close as it seems in this RFQ, you can't afford a high scrap rate (failed crimps, failed products in the field, etc).
__________________ Greg |
| Need A Quote- Small job - MDF pieces - from SW file | JohnnyVegas | Employment Opportunity | 2 | 01-30-2011 05:55 PM |
| Need Help!- Need Small pieces scanned | ArtistInFla | Digitizing and Laser Digitizing | 6 | 09-07-2010 03:35 PM |
| Need A Quote- 60 aluminum pieces | 387designs | Employment Opportunity | 7 | 08-06-2009 06:55 PM |
| RFQ- Aluminum pieces | pinkertonmax | Employment Opportunity | 8 | 11-19-2008 12:30 PM |
| Need A Quote- Small Aluminum rectangle pieces | TMaster | Employment Opportunity | 6 | 09-29-2008 05:49 PM |
