Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-30-2010, 07:23 AM
Pete_Ta1965's Avatar
Pete_Ta1965 is on a distinguished road
Exclamation JOB OPENING!!!
JOB OPENING!
MACHINING ENGINEER
Job Title: Machining Engineer
Primary Function: To create machined product in the most timely, cost-efficient, customer-authorized and drawing specific manner.
Principle Duties and Responsibilities:
• Creates CNC machining programs.
• Schedules machining.
• Creates time lines for part completion.
• Proves and edits machining program.
• Creates machining techniques.
• Establishes feeds and speeds for tools.
• Develops and implements new tooling methods.
• Researches tooling and purchases tooling.
• Designs model fixturing, jigs, and other devices.
• Works with outside vendors to have model fixturing externally quoted and machined.
• Makes decisions within broad limitations.
Minimum Job Requirements:
• Bachelor’s Degree in Engineering or over 10 years of training or experience.
• Able to work in a production environment.
• Able to read and comprehend English.
• Able to work with mathematical concepts such as probability and statistical inference, and plane and solid geometry and trigonometry. Able to apply concepts of fractions and percentages.
• Able to lift and carry up to 50 lbs. occasionally.
• Able to communicate effectively with co-workers and outside vendors.
• Able to write reports and business correspondence.
• Able to effectively present information to management and customers.
• Able to define problems, collect data, establish facts, and draw valid conclusions.
• Able to interpret an extensive variety of technical instructions in mathematical or diagram form and deal with several abstract and concrete variable.
• Able to use Microsoft Office applications.
• Complies with company and departmental policies and procedures, including company’s attendance policy.
Desired Competencies:
• Able to use Mastercam programming software.
• Able to use solid modeling software.
The above statements are intended to describe the general nature and revel of work being performed. They are not intended to be an exhaustive list of all duties, responsibilities, and skills.
Job Location
Ogden, UT, US.
Position Type
Full-Time/Regular
todd@competitiveedgerecruiting.com
Job opening qnet2 Employment Opportunity 1 11-18-2010 07:10 PM
Job Opening Veridiam Employment Opportunity 0 06-23-2010 10:39 AM
JOB OPENING naytep Employment Opportunity 0 09-23-2009 06:41 AM
Need Help!- Job Opening VTS_lyndon Torchmate 0 09-08-2009 04:51 PM
Need Help!- opening DOS bios cyclotron TurboCNC 14 03-24-2008 10:37 AM
