Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-24-2010, 11:57 AM
Erik D_lux is on a distinguished road
RFQ - Lathe & Mill work
I have some brass pieces that I need done. I worked with a local machinist so unfortunately I do not have drawings or code. I could send the piece for you to copy. It should be pretty simple and the tolerances are not too tight.
First pieces is a ring, made from 360 brass. 1.5" O.D., 1" I.D., .100 thick. It also has four holes for a 4-40 screw and is countersunk for a tapered head. I would be looking for 200 pieces.
Next piece is also from 360 brass. 1.5" O.D .500" thick. It needs to be milled out but should be pretty easy to figure out. I would be looking for 100 pieces.
Edit: The above piece also has the four 4-40 threaded holes that go all the way through the piece and it has one threaded 4-40 hole that goes through the O.D. toward the center.
Old 11-25-2010, 10:58 AM
*Registered User*
lyfordln is on a distinguished road
Where are you located?
Old 11-25-2010, 11:34 AM
dstryr is on a distinguished road
I'm interested. Shoot me your info.
Old 11-26-2010, 11:42 AM
Thanks everybody. I think I have it taken care of.
Need Help!- shoptask lathe spindle mill work leeharrysouth Shopmaster/Shoptask 3 11-13-2008 06:02 PM
RFQ mill and lathe work timmydabull Employment Opportunity 6 06-20-2008 03:48 PM
RFQ - Lathe & Mill Work - Toronto/GTA ngr1 Employment Opportunity 1 07-15-2006 10:48 PM
RFQ for Two Piece Lathe & Mill Work stang5197 Employment Opportunity 3 02-20-2006 09:17 PM
Anyone want to do a little lathe/mill work? Cold Fusion Employment Opportunity 5 07-27-2005 01:07 PM
