Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-19-2010, 06:37 PM
MicroSculpt is on a distinguished road
RFQ — Very small job
Greetings!
I am posting this to see if someone could possibly produce a small part for me. I only need one. The part will be used as a pattern for vacuum forming. The finished object will be small — about 1 3/4" x 1/2".
The only truly critical dimension is the concave curve that the plastic will be sucked into. The drawing shows accuracy to three decimal places. Other than the concave area, the rest of the dimensions do not need to be that exact and in fact, the dimensions can be adjusted if necessary.
I have a profile that I created in Adobe Illustrator that I can provide so that this does not need to be redrawn. I can provide a spline if you let me know what format you can import.
Hopefully this should primarily be a simple lathing process. After lathing (or before?), a .010" hole will need to be drilled at the center point for air to escape out of the pattern.
Please let me know if this is possible and approximately how much it would cost. I am flexible about the material as long as the completed piece has a very smooth finish (in the concave area) and can withstand low heat.
I look forward to your response. Thank you.
Tom Sollers
Old 11-22-2010, 05:53 PM
Frantic Fab's Avatar
Frantic Fab is on a distinguished road
Hello Tom,
I am Garrett Gordon, i work for Masterpiece Models we are a complete full fabrication shop! check out our website and if your interested we can make this form for you. we aslo specialize in thermo/vacuum forming so it would be very easy for us to simply send you the finished product!?
please get back to me if this spikes your intrest Tom
garrett.gordon@masterpiecemodels.com
Masterpiece Models
7907 ne St. johns rd.
Vancouver WA, 98665
(360)256-1488
"What Can We Build For You?"
Looking for small VC Captdave Want To Buy...Need help! 0 10-08-2009 03:26 PM
How small is small? Halfnutz Machine Created Art 40 06-15-2009 01:08 AM
Measuring small angles on small workpieces. skiingman Calibration & Measurement 1 04-01-2009 07:40 PM
The bit is HOW small? Rhodan General Electronics Discussion 0 12-05-2007 10:59 PM
small CNC- plz help Papcina Open Source CNC Machine Designs 2 03-08-2007 03:18 PM
