Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 11-02-2010, 09:29 AM
Sheepspeed is on a distinguished road
RFQ - Quote for cnc turning job, EN8 mild steel lot of 500
Hello,
I am looking for a quote for the attached in mild steel en8.
300 of 1-2unf bush.igs
100 of 5-8unf bush.igs
100 of 3-4unf bush.igs
Jim
Old 11-02-2010, 10:01 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Hi Jim
Can you give the tolerances please
Phil
Old 11-02-2010, 10:07 AM
not sure on terminolgy here, thread has to be pretty close, but the od and legnth can be within .5mm
Quote Awarded 1" mild steel milling LarryRichardson Employment Opportunity 0 09-29-2010 07:31 AM
Need Help!- speed for turning mild steel noshoesnoshirt General Metalwork Discussion 1 08-16-2009 09:31 AM
Mild Steel on a cnc router? trooper55 General Metal Working Machines 5 08-07-2008 12:43 PM
Mild Steel MBG General Metalwork Discussion 1 03-09-2007 04:20 PM
Machining Mild Steel georgebarr General Metal Working Machines 5 06-29-2005 06:54 PM
