Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-27-2010, 01:53 PM
TwistedGray is on a distinguished road
Syntactic Foam Floats Needed
Hello,
We are a small underwater company in Monterey Bay, California.
We designed a float to go on a small device that will pop-off an animal, float to the surface, and transmit data via satellite.
I am having a hard time finding someone that has worked with syntactic foam. I have three float designs that I need manufactured. I have the syntactic foam already (HP-24).
I also have the drawings available (pdf) along with Solidworks files if necessary. Please email me at tgray@desertstar.com
Attached image is one of the three floats we want machined.
Thomas
Need A Quote- Foam wire cutter needed turmite Employment Opportunity 5 12-23-2009 09:12 PM
What power is needed to cut thin foam? Witsenburg Laser Engraving & Cutting Machines 4 10-18-2008 05:44 AM
Contract foam cutting needed 43220 CNC Wire Foam Cutter Machines 4 04-01-2008 12:05 PM
Thinnest insulation foam (XPS) supplier needed salvaCNC CNC Wire Foam Cutter Machines 0 02-03-2008 11:00 PM
Syntactic Foam JavaDog General Material Machining Solutions 12 08-12-2005 03:26 PM
