Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-24-2010, 08:30 PM
ahaidet is on a distinguished road
Small Aluminum Parts Mill Work
I have several parts that I need machined for an assembly. I have machined them before on a friend's CNC however he got out of the business so I want to see what it will cost to have these made without the "friend" discount.
Depending on the cost I may be interested in ordering a larger initial batch than the QTY listed below so if you could give a quote that shows how the price changes with larger quantities that would be great. Also this will likely be a reoccurring order based on how quickly I can sell the initial order. If they continue to sell like the previous assemblies I made, it will be quick.
The first items I need are what I will call Part 1 and will be mill work. The outer dimensions likely will not need to be machined as the dimensions are not critical and is a standard aluminum stock size. There are two sides to Part one that bolt together. One side is tapped as indicate in the following drawing.
The other side has the same 1/4-28 holes on the side but has a through-hole in the middle that is counter bored for a low head cap screw.
Part 1 tapped QTY: 9
Part 1 through QTY: 9
If you have the ability to anodize then please quote both finished and unfinished pieces.
I have some other parts that need machined to complete the assembly. But I will list the others later. I have IGES files of the parts listed here that I can send you upon request.
Old 10-25-2010, 09:36 PM
TNBG_LTD is on a distinguished road
Quote Sent.
Old 10-26-2010, 04:05 PM
doughtybrian is on a distinguished road
P M with quote has been sent.
Thanks Brian
Old 10-26-2010, 05:24 PM
fannin_t is on a distinguished road
Quote
I have a quote of 18 parts 9 with taped hole and 9 with out and delivery in two weeks
Old 10-27-2010, 10:42 PM
Thank you all that bid this part. The job has been awarded. I will post other items soon to complete this project.
Need A Quote- small aluminum parts jeremy0203 Employment Opportunity 3 10-12-2010 07:45 AM
Need A Quote- Small Run CNC Aluminum Parts m7king Employment Opportunity 8 04-17-2010 08:57 PM
Need A Quote- RFQ Aluminum parts for small CNC mill southernexplore Employment Opportunity 6 10-02-2009 11:08 AM
RFQ - Small aluminum parts JeffEmbracedDC Employment Opportunity 15 11-19-2008 09:45 AM
RFQ: Mill and Laser/WJ Work, 2 Aluminum Parts kend Employment Opportunity 2 04-30-2007 05:01 PM
