Results 1 to 2 of 2
Thread: 4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts
    Oct 2010
    California, USA
    First job is 4 6061 turned adapters. I'll provide the material: 4x 6"x1.75" 6061T6 (from onlinemetals.com).
    Second is a pair of steel adapters, which are mirrored about their center plane. I don't have the material for this--they should be steel, 1018 or 1020.
    Part files for all three parts are attached (I can save in other formats if you want), including drawings (none of these parts have particularly tight tolerances expect for the 10* taper on the spindle). Speaking of which, I have a 10* taper reamer I can send if it would make things easier--1/2" shank.
    These are one-offs, so I probably won't be ordering any more in the future. Also, I don't mind using two shops if you only want to quote one of the jobs. Send me a PM, thanks!
    Attached Thumbnails Attached Thumbnails 4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts-drop_spindle.pdf   4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts-drop_spindle.jpg   4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts-960r_wheel_spacer.jpg   4 150x35 6061 discs, and 2 200x38x75mm mirrored steel parts-960r_wheel_spacer.pdf
    Attached Files Attached Files
    Oct 2010
    California, USA
    Job awarded, thanks everyone.
  1. RFQ 6061 T6 simple 2 axis parts.
    By nate in forum Employment Opportunity
    Last Post: 08-13-2010, 07:58 AM
  2. mirrored parts problem
    By MadPickinSkills in forum DIY CNC Router Table Machines
    Last Post: 08-01-2009, 12:29 PM
  3. 1018 Steel vs 6061 Aluminum
    By trmpyro in forum DIY CNC Router Table Machines
    Last Post: 01-30-2009, 09:21 AM
  4. Parts RFQ Machining 6061
    By hoju1301 in forum Employment Opportunity
    Last Post: 07-11-2006, 07:07 PM
  5. Punching discs out of 4mill stainless steel
    By ChrisJ in forum General Metalwork Discussion
    Last Post: 03-03-2005, 06:50 AM
