Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 10-11-2010, 09:44 AM
jkarisny is on a distinguished road
Small Saw Shaft
I need a saw shaft made and I do not have access to the right equipment.
I have had some ridiculous quotes from some area fabricators/machinists, so I thought I'd try here.
I only need a quantity of (1)
Material: Steel or stainless
Shaft will be spinning at around 10,000 RPM
Thank you,
Old 10-11-2010, 09:49 AM
Oops, double post. Admin please delete duplicate post.
Need A Quote- Small Saw Shaft jkarisny Employment Opportunity 7 10-12-2010 01:01 PM
Can somebody make a small shaft adapter for me in the UK? adamchapman General Metal Working Machines 3 06-14-2010 04:43 PM
Measuring small angles on small workpieces. skiingman Calibration & Measurement 1 04-01-2009 07:40 PM
Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft DonW DIY-CNC Router Table Machines 7 03-17-2008 03:58 PM
Small hose clamps - screw to shaft coupling? Chris D Mechanical Calculations/Engineering Design 5 03-20-2006 12:50 PM
