| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
edit: sorry the title is incorrect. i actually need 500pcs total (not 300). please see below for full info: Hi CNCzone community! I've been trying to find someone who can produce some extremely simple shapes out of aluminum flashing (very, very thin). It is for a small project I am working on so I do not need a huge quantity. I require 200-pieces of both of the following: 1) A rectangle shape: 1" x 9.894" (does not to be exact, just close) 2) A "C" shape that is approximately this: this 2d piece will be attached on end to create a funnel shape: I have also attached a .dxf file that was exported using the program in the screenshot. I will also need 100 of the following: 3) A rectangle shape: 1.5" x 6.802" (does not to be exact, just close) The material should be aluminum flashing (approximately the thinness of a soda can). There will be a potential for additional orders in the future. Please let me know if you can do this, and how much it would cost. Thanks! Tom Last edited by theorie; 10-03-2010 at 12:16 PM. |
| Hello. since this material is so thin, why not just cut out the parts you need with scissors? if you're worried about accuracy than just print out your drawing with a 1 to 1 scale and use it as a template. If this won't work for you for what ever reason, then I will give you a bid |
| i'm sorry everyone, i just noticed a problem with my post title. it should say 500pcs (200 + 200 + 100). thank you.
| Need Help!- No LSK Flashing on Fanuc 0M-B | ixoxi999 | Fanuc | 1 | 09-08-2010 12:30 AM |
| Flashing | hjl4 | Viper Servo drives | 1 | 07-07-2010 10:50 PM |
| Need Help!- TEK10 red LED keeps flashing | bartL | TEKdrive Servodrives | 2 | 10-19-2009 03:10 PM |
| Need Help!- Need Help Alarm Flashing | Pmp Audio | Fanuc | 3 | 06-23-2009 09:46 PM |
| Need Help!- Flashing bit | mr_electrician | Fanuc | 3 | 02-15-2008 01:19 PM |
