Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-29-2010, 07:31 AM
LarryRichardson is on a distinguished road
1" mild steel milling
I need quantity 1 of the following attachment.
This is a slightly modified version of the Ron Steel CNC Mini lathe part, and is used to connect the leadscrew to the cross slide assembly.
The center hole is .625 (there was a conflict on the drawing, the dim is right)
Material should be Mild steel 1018 or similar.
Include lead time, cost & shipping estimate to 40014 (Louisville KY area)
Thank you
Fine-cut consumables - 1/4" mild steel energyforce CNC Plasma and Waterjet Machines 2 04-29-2009 07:13 PM
Cutting 1" Mild Steel 3DSteve CNC Plasma and Waterjet Machines 14 06-14-2007 04:58 AM
RFQ: Milling needed in mild steel. SCCoupe Employment Opportunity 2 12-10-2006 08:06 PM
RFQ - on 1/2" mild steel plate BullCreek Employment Opportunity 5 07-10-2006 06:31 PM
A Mill for milling HSLA and Mild Steel deep_drill General Metal Working Machines 3 06-06-2005 11:29 PM
