Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-27-2010, 01:44 AM
diyengineer's Avatar
diyengineer is on a distinguished road
(4) pieces of 1/2" plate machined ASAP. RFQ
I need a rough estimate on how much these would cost to machine. Everything can be cut from 1/2" aluminum plate. Overall dimensions are shown in the pictures for simplicity. If you need more specifics please Private message me. I need a ballpark price. Some of the holes need to be tapped after machined. If you can do this as well it would be a plus but not required whatsoever. The inside square corners i can fillet or chamfer as well if that makes it easier for you to get a endmill in there. please advise. I can modify to accommodate. Plans are 95% done. Very slight modifications will be implemented. I will send you the final plans via email, or post them up in the next few days. For the sake of time though, please shoot me a rough quote.
I need this done asap. It converts my cnc mill X axis from ballscrew to rack and pinion drive.
Here is a link to the huge thread i have posted about the rebuilding of my machine if you care to read.
http://cnczone.com/forums/showthread.php?t=103291
Thanks!!!!
ID:	115605   Click image for larger version
ID:	115606   Click image for larger version
ID:	115607   Click image for larger version
Name:	assembly overview.png‎
Old 09-27-2010, 06:10 AM
Cartel, LLC is on a distinguished road
pm sent
Old 09-28-2010, 04:34 AM
Hopefully today i will get the plans posted. I HATE 2D Drawing, so bare with me.
Old 09-28-2010, 01:23 PM
universalfab is on a distinguished road
PM Sent..
Old 09-28-2010, 04:44 PM
Updates:
Added Radius to inside corners.
Fully defined sketches.
Finalized plans.
Attached:
One Zipped up folder.
Contains (2) pictures:
Assembled picture
Exploded assembly
Contains (4) PDF documents, one to each part:
Flange Top
Flange
Motor Flange
Spacer
Please take time and check over the plans to make sure i did not miss a dimension you will need.
Old 09-28-2010, 04:49 PM
Thumbs up
If you have Solidworks and would like the the files as well, please email me and i will send you over the zipped up parts and assemblies folder. It contains all the drawings as well as the full 3D files. It is roughly 5-6 Megs in size.
Please bring any missing dimensions to my attention.
Thank you.
diyengineer AT Gmail dot com
Old 09-30-2010, 11:57 AM
So-CalPrecision is on a distinguished road
Can you please send the prints to socalprecision@verizon.net so we can work out a quote. Thank you.
Old 09-30-2010, 05:34 PM
send the files to me as well. thanks.
jerzfabguy@yahoo.com
Old 09-30-2010, 09:03 PM
Thumbs up
I am going a different direction. Instead of 1/2" 6061 Aluminum I need someone to use a router or mill to cut the parts from MDF or plastic (1/2"). You can buy a whole sheet of MDF just about at any lowes store or home depot for $20 bucks.
I'm going to start a new thread, consider this one dead.
Going to use the routed pieces as a mold and cast them out of aluminum using green sand which i have had great results doing. This opens up the job to almost anyone with a router cnc. The holes do not need to be tapped just bored through as indicated.
Since this changes things up a bit please Re-apply in the new thread of PM me.
thank you very much!
Need A Quote- Cold-rolled steel plate, 13"x24", 1/2" thick. Odin Want To Buy...Need help! 1 02-22-2010 09:00 PM
Need A Quote- .125" AL plate, cut (mill or laser), bent .125" ID bends Sporqster Employment Opportunity 0 09-23-2008 03:41 PM
Need A Quote- 4 or 8 pieces "Simple Aluminum hdd tray" snowcnc Employment Opportunity 1 06-09-2008 07:54 AM
RFQ: pieces of 0.5" baltic birch plywood in LA gmed Employment Opportunity 2 09-03-2007 04:27 PM
Rfq Machined Aluminum Plate Philip Employment Opportunity 6 08-21-2006 10:15 PM
