Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-22-2010, 10:26 PM
bostosh is on a distinguished road
Cool 120 small parts milling alum hi-speed 3-d contouring holes
3-D contouring, milling, drilling, reaming, tapping, profiling,
We need 120 parts, You or me do machine program option.
MCAM x3 geometry file supplied, .IGES, most other types too.
Possible repeat work.
1) Material type
alum. 6061 bar 2.000 x .750 x 16.5" x 10pcs or your option.
2) Is a material quote required or is material supplied?
Supplied or You to procure from any source, cut plates or barstock.
3) Quantity ?
120 parts on 10 bars
4) Drawings should be immediately available or necessary specs. (link supplied)
Full cad support any 3-D CAD file type, no .PDF's
Complete package in a .ZIP file posted on website LINK Here.
http://members.cox.net/bostosh0/This%20for%20RFQ.zip
5) Required time frame ?
ASAP or negotiated delivery schedule.
6) RFQ ending time ?
when job is let.
7) Full contact information should be supplied upon first contact by email from both parties,
neither should have to reply to rfq@.com ( We will not )
Brian Ostosh <bostosh@cox.net>
Robert Guthrie <bgsnares@yahoo.com>
8) If you the RFQ poster needs help in some of the technical areas then that should be made know initially.
We need no additional help, just program, run and deliver,
Basic +/- .002-.003 tolerances on hole locations, good threads (roll or cut), Body tolerance +0,-.010
Yes I will and can do conventional (old-school) inspection of first article, full bar, or minimum 3 pcs (short bar)
Overnight mail if necessary.
We will deburr and finish the machining scallop marks on fillets.
Your program scallop height = .001 or less. (Use those new software routines)
Figure a clamping and tabbing scheme, vise set-up ok
Please call for confirmation of tooling plan,
Like-maybe the entire quantity be run on a larger X,Y array and
With a .005-,0100 web part-to-part tab along long sides.
Maybe double-back Scotch and the flat side down.
Use those High-Speed router bits light cuts to part-off.
We can part-off and finish .3125 side hole.
9) Make known any special treatments/finishes not necessarily related to the machining process.
Please do not gouge nor bang-up the 2.000 or .750 raw stock dimensions, these are not critical dimensions but will get a polishing. (This is the "ART" of the "part") These dimensions can be up to .005-.010 under.
In other words, the stock could be fly-cut square-up for those stock dimensions, Please protect finish surfaces.
Thanks for the interest in your bid.
Been doing this too long
Old 09-23-2010, 01:52 AM
universalfab is on a distinguished road
Your link didn't work for me, you think you could just attach the file to your thread? Thank You, appreciate it.
Old 09-24-2010, 08:44 PM
UWP_Wes is on a distinguished road
Email sent. The bostosh@cox.net address does not seem to work.
Old 09-26-2010, 08:51 AM
Cartel, LLC is on a distinguished road
please send me the files as well. thank you!
joeyb@theindycartel.com
Need Help!- Best Cnc for small 6061 alum. part. duaneblk@yahoo. General Metalwork Discussion 17 09-28-2009 12:30 AM
Need Help!- Help milling small holes in polycarbonite Ferny General Metalwork Discussion 3 04-10-2008 09:05 PM
Ware, How, And If To Start Milling Small SS Watch Parts mabmojo General Metalwork Discussion 14 01-09-2007 08:57 PM
contouring aluminum with small bit corpse Benchtop Machines 6 09-14-2004 01:11 PM
Feed/Speed Milling Alum Rekd Hard and High Speed Machining 7 11-26-2003 10:55 PM
