Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-10-2010, 12:00 PM
ez3022 is on a distinguished road
Hex Bar Stock turned and drilled/tapped
I need qty 100 of these items. I would like quotes to offer material options of mild steel and 7075 Aluminum. Based on pricing, I will select one of the following two designs and material. The job is time sensitive, turn around time needs to be less than 2 weeks. The first part in question is 3/4 hex stock, approx 2.33" in length, turned to a 60 degree taper on one end and drilled and tapped for a 12x1.5mm through hole. The second is based on 1 inch round stock with the same taper and through hole. The hex is machined in this version. Preference will be given to Los Angeles area shops. I will not consider overseas suppliers.
Thanks You.
Old 09-12-2010, 02:55 PM
dstryr is on a distinguished road
PM sent.
Old 09-12-2010, 05:17 PM
universalfab is on a distinguished road
PM SENT...
Old 09-30-2010, 12:01 PM
So-CalPrecision is on a distinguished road
Can you please send the prints to socalprecision@verizon.net so we can work out a quote. We are located in Cerritos, CA. Thank you.
Old 09-30-2010, 06:04 PM
Have you awarded this job yet? We sent you a quote about 2 weeks ago...
Quote Awarded RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled) AuroraDrvr Employment Opportunity 5 04-14-2009 01:12 AM
Drilled & Tapped Precision Shafting justCNCit Mechanical Calculations/Engineering Design 3 12-23-2008 05:56 PM
RFQ 34 - Small manual job - Offset turned and cross drilled hardened locking pin InspirationTool Employment Opportunity 9 09-12-2006 07:26 AM
RFQ - small mild steel turned and drilled parts mcmmach Employment Opportunity 8 07-28-2005 09:37 PM
Are sherlines drilled and tapped?? BriteHarry Mini Lathe 1 10-14-2004 07:36 PM
