Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 09-01-2010, 02:19 PM
Tallen is on a distinguished road
Aluminum mounting plate
Let me start off by saying that I am looking to build a good working relationship as I have thoughts brewing for other projects. Basic DXF files are already made.
Looking for, an introductory, total of 50 (15/35) of two slightly different mounting plates. Plenty more to come.
Plate size: 14.9" x 2.9"
Ten circular holes. Four are 1.2", four .2", and two .33". I will be tapping the .2 holes for 1/4-20 so it needs to be reasonably accurate, rules out plasma.
1/4" or 15/64" aluminum.
Ability to engrave is desired as I may want to add that into the quote. 13 characters 3/8" tall in the bottom center of the plate. NOT required at this time.
Alloy does not matter, the cheaper the better. Piece will be powder coated but a decent surface finish is a must.
Reply to the thread with any questions, PM me with quotes.
Edit: Located in Northern Virginia
Old 09-01-2010, 02:27 PM
csirocky2 is on a distinguished road
Where are you located? I am in Minnesota and it sounds like something we would be interested in quoting for you.
Old 09-01-2010, 02:34 PM
Edited the initial post, thanks. Northern Virginia.
Old 09-02-2010, 06:57 AM
All PMs/emails replied to! Thanks guys. Keep em coming.
Old 09-02-2010, 08:03 AM
jimcolt is on a distinguished road
You could do that part with a high degree of accuracy with plasma, and at the lowest cost. For the small holes that you will tap....let the plasma torch cut them undersize as a location...then use a drill press to properly size the holes after cutting. Should be able to keep hole locations within a pus or minus about .005".
Here is a pic of a recent aluminum job done on my plasma system. These were done with an air plasma on a low cost cnc machine.....could be much better if done on a precision machine with a high definition plasma system.
Jim Colt
ID:	113764   Click image for larger version
Old 09-04-2010, 02:51 PM
Hey guys, got my Inbox empty now.
Got quite a few quotes in the low teens per plate, should have a supplier chosen soon.
milling plate aluminum eloid DIY-CNC Router Table Machines 12 02-08-2010 11:27 PM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 12:48 AM
Where do you get your aluminum plate Cold Fusion General Metalwork Discussion 20 01-27-2006 12:37 PM
RFQ Aluminum plate work Cold Fusion Employment Opportunity 4 12-14-2005 09:15 PM
RFQ - Aluminum mounting part scopEDog Employment Opportunity 4 08-31-2005 09:28 AM
