| Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here! |
I can supply an STL file, bidders must have continuous 4th axis CAM and machining capability. Part is about 8" long, 1" diameter. Material is not important, but smooth surface finish is required (will be used as a core for a rubber molding operation). Stepover at most 0.020", with a 1/32" or smaller ball end mill (lots of fine surface detailing must be captured in the machining process. Multiple passes requested to reduce visible scalloping on the machined surface). No, it's not a dildo! ![]() Please e-mail me at mike(at)mcpii(dot)com if you are interested in quoting, and I will supply the STL file. I would like to see references and/or previous 4th axis work you have done. Would also like to know what CAM package you will use, and what machining equipment will be used. Serious inquiries only, please (no Taigs, Sherlines, or other "play" machines, please). Last edited by mcphill; 08-29-2010 at 01:38 PM. |
| I would send you a PM, but for some reason I can not open up my private messages or send anyone else a private message. What's going on, is there something wrong with the website? Did they permanently take the private messages away? Or are they just picking on me? I would like to know anyone with any information please explain. |
| Sorry Mike I usually like this sort of thing but we are too busy and it is one of those jobs that will require a lot of "messing around"
| All e-mails and PM's replied to. If you did not receive a response, please reply to my e-mail address above. Note, I only have this as an STL file. If your CAM program cannot run from an STL file, you cannot do this job. That said, it is not that hard a job - DareBee, sure you're not interested? |
| If you need a really smooth surface, an STL file is not the best way to go. You dont have it in any other format? Mike Mattera
__________________ Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More http://www.tipsforcadcam.com |
| No one has quoted yet, I think I will just get them SLA'd, or maybe my Dimension printer will be good enough... |
| Rotary axis help required | kashifbashir | Mechanical Calculations/Engineering Design | 3 | 05-05-2011 02:09 AM |
| power supply required for 4 axis system | hpghost | Gecko Drives | 2 | 12-18-2008 10:34 AM |
| G320/G340 'Required Direction Setup' and 'Required Direction Hold' times? | margni74 | Gecko Drives | 2 | 12-05-2008 08:10 PM |
| Smooth motion required high feed 3 axis surface milling | cncjoy | Fanuc | 11 | 10-13-2007 01:03 AM |
| Required to delete axis from Turning centre | Vishal N | Servo Motors and Drives | 1 | 06-02-2007 02:08 AM |
