Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-22-2010, 08:00 PM
zonker is on a distinguished road
Need a quote
I have several figures I need cut in relief from polystyrene foam. They vary somewhat in size but an average would be 5 inches by 5 inches with a Z height of 1/2 inch. I will have others of similar measurements in the future but my needs are somewhat dependent upon the cost. I have a homemade cnc router but it is quite slow and although it meets my needs admirably for vcarving its not quite practical for 3d. I have quite a few softwares at my disposal and can provide obj, stl, rlf files or can produce code from Artcam or RhinoCam.
The figures need to be one sided reliefs That I will be making molds from to cast wax into to use for lost wax casting. If the cost turns out be too high i will just bite the bullitt and run my machine for a day or two straight. thank you in advance for your time and consideration.
Name:	ZBrush Document copy.gif‎
Visit Dagger and Rose 3D Vector Tattoos at http://daggrnrose.sqweebs.com
Need a Quote.... SatanKlawz Employment Opportunity 2 09-02-2009 06:00 PM
Will you quote to this RFQ? titan99 General Business Practices and Pricing 3 08-22-2009 04:45 PM
Quote and Multi-Quote JoBwan Test Forum 0 02-23-2008 05:58 AM
need a quote joey1117 Employment Opportunity 5 02-05-2007 03:26 PM
Quote please elmor fudd Employment Opportunity 2 03-21-2006 04:58 AM
