Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-09-2010, 10:29 AM
nate is on a distinguished road
RFQ 6061 T6 simple 2 axis parts.
Please see the attached file.
The parts need to be 6061 T6 from flat stock. no finishing on the top and bottom is allowed, must remain mill finish. They need to be cut .025 - .050 oversized for finishing ops.
They can be cut on a VMC, plasma, waterjet or laser. the kurf can be crooked, but they must be oversized enough to finish at the dims on the print.
As you will note on the drawing, 2 of the parts are .375 thick and the other is .500 thick.
Please quote quantitys of 20, 50 and 100 of the .375 thick parts. with and without material.
Please quote quantitys of 40, 100 and 200 of the .500 thick part. with and without material.
Ship time must be within 30 days of agreement.
Continental U.S. contractors only.
Please forward any questions and bids to natefoerg@gmail.com
when this is awarded I will post that it has been. If I have not posted that the job has been awarded, assume that bidding is still open.
Thanks,
Nate.
Nate.
Ann Arbor Meechigan
Old 08-10-2010, 02:08 PM
Moderator
beekeeper is on a distinguished road
empty pm box
your pm box is full
BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS
Old 08-10-2010, 02:42 PM
pm box empty.
Sorry about that. pm box is ready for messages now.
Nate.
Ann Arbor Meechigan
Old 08-13-2010, 05:57 AM
cro-magnum is on a distinguished road
I only see the parts on my end no dims or thickness
Lets see if the scale is correct
The large part is 6.525 X 2.349 measuring linear across the part
Thank you
Travis
Old 08-13-2010, 06:10 AM
gabedrummin is on a distinguished road
Turn on iso after you open the drawing and you can see z depth
Old 08-13-2010, 06:58 AM
didn"t think of that now I know which is which, but still need to check the scale.
Thank you Sir
Travis
need quote 6061 aluminum parts cncsdr Employment Opportunity 9 02-25-2010 09:38 AM
Need A Quote- 2 small 6061-t6 HEX bar parts. LATHE only aaron p Employment Opportunity 10 04-20-2009 11:34 PM
Need A Quote- Simple 1/4" thick 6061 plate Aaron92SE Employment Opportunity 1 05-16-2008 04:47 PM
machine some parts for my project - 6061 Aluminum josephmartins Employment Opportunity 5 10-11-2007 06:16 PM
Parts RFQ Machining 6061 hoju1301 Employment Opportunity 6 07-11-2006 06:07 PM
