Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 08-03-2010, 02:52 PM
Pressco is on a distinguished road
Arrow Kent, WA - Press & Secondary
We are a small aerospace shop in Kent, Washington that has two openings as of 8/1/2010. We are ISO and AS9100 certified. We work 4-10s, offer competitive wage and benefits including health, vision and dental insurance, and have been in business for 45 years.
Position: Press Operator
Summary: Sets up and operates power press to blank, form, bend, stretch and straighten metal plates, extrusions, and sheet as specified by blueprints, layout, and/or template.
Essential Functions:
-Installs and aligns dies in press according to specifications using shims, templates, bolts, clamps, and wrenches. Adjusts ram stroke to required length.
-Inspects work and changes dies when making multiple or successive passes.
-Starts press and observes operation to detect misalignment or malfunction.
-Hand forms or finishes (including deburr) workpieces using available tools.
-(May) Assemble dies or set dies to punch and blank heavy metal.
-Communicates with co-workers and supervisor to coordinate activities.
-Accurately inspect and measure parts to maintain statistical process control charts.
Requirements:
One of the following -
- Six months or more of trade or vocational school
- 1 year or more of related work experience
- 1 year or more of related apprenticeship
2nd Position: Secondary Department Operator
Summary: Operates under supervision various machines and tools to manufacture and assemble parts per work order, supervisor, and blueprint instructions. May operate foot presses, riveters, hand coilers, drill or punch presses, power brake, finger brake, deburring equipment, conventional mills, etc.
-Use hands and various tools to construct small and sub-assemblies.
-Bonding with adhesives and touching-up assembled components with paint.
-Use drill or other presses, riveter, hand or power tools to to trim, bend, form, deburr, and assemble metal and plastic components.
- (May) Learn to read blueprints, mix adhesives, operate other equipment or be responsible for holding dimensions.
Requirements:
- High School Graduate or GED
- Previous related work experience
-This section relates to both positions-
Physical Demands:
Employee may be required to
-Stand, walk, push, pull, reach overhead, or bend to the floor.
-Exert up to 50lbs of force to move objects
Visual Acuity
Should be able to read fine print (such as blueprints), calipers, dial gauges, and other precision measuring devices.
Hearing Ability
Should be able to monitor machine or tool sounds to identify and diagnose changes and take appropriate corrective/preventative actions.
The position descriptions above are NOT inclusive and there may be other requirements not listed. If you qualify for the position or would like more information, please send an e-mail (or PM) to garagesale@pittraffic.com
Thanks!
Job Opening CNC Machinist - KENT, WA Pressco Employment Opportunity 0 02-08-2010 10:56 AM
Job Opening Press Brake Operator - Kent, WA Pressco Employment Opportunity 0 12-17-2009 04:43 PM
Need more I/O on secondary paralellport corydoras Controller Cards 0 01-12-2008 01:18 PM
Greetings All! Help! Fanuc-Kent Mill adodado Fanuc 5 09-07-2006 10:50 PM
Toroid second secondary? Bloy2004 General Electronics Discussion 4 08-18-2005 12:53 PM
