Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-31-2010, 05:52 PM
m78kem is on a distinguished road
Exclamation Looking for CNC operators for permanent and contact roles in europe
I have some openings in europe for CNC operators I currently have 3 roles for permanent positions in the UK, Derbyshire, Cambridgeshire and Surrey.
I also have contract roles in the Med for Millers and turners.
The contract is set to start in September and will continue for at least 6 months, possibly longer - there is also a possibility of permanent conversion. Travel, accommodation and local travel will all be supplied by Excel and you can expect to be working at least 50 hours per week, with the opportunity for more.
In order to be considered for this position, you must have at least 5 years experience of working on CNC milling machines (5 axis) or CNC Lathes, and ideally have experience of Heidenhain controls with FPT milling machines or Fanuc controls with Mori Seiki/Graziano machines. Previous experience with machining composites would be a benefit.
This is an outstanding opportunity to take an interesting, challenging and diverse position within one of Europes leading production companies so if you have the experience, what are you waiting for??!!
If you are interested in any or the roles please send me a cv to mark@exceltechnicalconsulting.com
Tags
employment, europe, job, miller, turner
CNC Programmers/Setup Operators/Supervisors/Engineers Needed for Permanent Positions DustinTSE Employment Opportunity 1 01-17-2011 01:07 AM
Job Opening Motion Engineer (Permanent) ag53711 Employment Opportunity 0 05-18-2010 11:52 AM
Roles of machines MecInd General Metalwork Discussion 1 01-25-2009 04:45 PM
Temecula,CA...CNC Machine Operators and Set Up Operators BG-CEMMS Employment Opportunity 0 01-09-2007 11:39 PM
Immediate Start in Southampton - Permanent sebkarlsson Employment Opportunity 0 10-04-2006 03:03 PM
