Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 07-13-2010, 09:11 PM
Toggleme is on a distinguished road
Turned Aluminum Handles
I am looking for a quote for 200, 300, and 400 units of the below drawing. Despite what the drawing says - the material is 6061 T6 aluminum. The surface finish is critical to the part but many of the other dimensions can be loosened up if needed.
Currently the lowest quote is $5.17 FOB Los Angeles, CA for 200 units with 15 day delivery.
Please contact me via PM.
Old 07-14-2010, 01:06 PM
jeffrey.norman is on a distinguished road
I can machine this part complete for (200) 3.42 including shipping, material everything. 300 pieces at 2.89 and 400 at 2.62. look us up at www.torquemachining.com
Old 07-14-2010, 02:01 PM
Jeffrey, can you also provide additional cost for polishing of the outer surface?
Old 07-16-2010, 11:59 PM
Jonson nike is on a distinguished road
Cable boxes aren't traditionally good at amplifying sound. There's usually a setting that will come up somewhere in the middle of the volume selection that is the ideal position, and then just use the volume control of the television or of your stereo system to control the volume level.
Need A Quote- RFQ - More Turned Aluminum Pieces...... AuroraDrvr Employment Opportunity 2 11-01-2009 09:03 PM
Need Help!- handles Claude Boudreau BobCad-Cam 9 10-22-2009 08:19 PM
RFQ - Two Small Turned Aluminum Parts AuroraDrvr Employment Opportunity 6 04-18-2009 02:02 PM
RFQ - Turned Delrin/Nylon/Aluminum AuroraDrvr Employment Opportunity 3 03-03-2009 12:05 AM
Need A Quote- Turned aluminum piece raidfibre Employment Opportunity 5 02-19-2008 07:39 AM
