Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 06-08-2010, 10:01 PM
Mack4613 is on a distinguished road
CNC Mill/Lathe Programmer Alexandria, MN
CNC Mill/Lathe Programmer/Machinist in Alexandria MN
This Sucessful candidate will have the ability to operate and program both Mill and Lathe
Set-up and manufacture parts to print
GibbsCam experienc preferred but not nesessary
If you are interested in learning more about this position
Contact:
Sophia Mack
sophiamack@msn.com
(952) 250-3980
Job Opening CNC Lathe setup & programmer needed near Indianapolis, IN 6thAxis Employment Opportunity 1 03-29-2012 07:16 PM
Job Opening CNC programmer-6 & 8 axis lathe autoairguns Employment Opportunity 0 01-27-2009 06:21 PM
Job Opening Programmer and Mill Machinist Needed TB4 Employment Opportunity 2 01-12-2009 11:38 PM
NEED CNC PROGRAMMER & OPERATOR FOR A VERTICAL MILL ksmith46516 Employment Opportunity 0 03-06-2008 11:11 AM
Job Opening CNC Lathe Machinist / Programmer Wanted dcoupar Employment Opportunity 0 01-23-2008 01:25 AM
