Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-24-2010, 04:39 PM
Greg Koziol is on a distinguished road
NEED A QUOTE - small aluminum prototype 3.5" long Drawings attachment
I need to machine a prototype out of aluminum 6061. And if I can find customers and I like the price possibly someone to do some light production.
It's a small part, I have more detailed CAD drawing on CAD if necessary
So far here is the best quotes I got:
$1,202 from Firstcut.com
$850 from tool tek inc. a local machinist near my house
I was hoping I could find someone who can machine this for signifianctly cheaper than both of those
Holes need to be threaded and the giant u-shaped tunnel needs to be tapered... althought not shown in the picture it will need a .6 degree taper in it
Dimensions are rough dimensions just to give an idea of the size of it
those rails have groove and the groove need to be exactly .206" wide and .394" center to center. The cross section of the rail also needs exact measurments with close tolerances.
Name:	marlin tri rail new.jpg‎
ID:	107800   Click image for larger version
Name:	marlin tri rail new 2.jpg‎
ID:	107801   Click image for larger version
Name:	marlin tri rail new 3.jpg‎
Old 05-24-2010, 04:55 PM
Matt@RFR is on a distinguished road
Exactly where is your pain threshold on the prototype? The quotes you've got so far are not that far off. They are a little bit high, but not much. This is a 4th axis part, minimum 2 setups with some deep 3D machining...it will take some time, and that aint free.
And you mention 'light production'. What kind of quantities do you have in mind? Nobody can quote a production price unless you give a little more info. I know quantity will probably be driven by price, but are we talking a production run of 10 pieces, 100 pieces or 10,000 pieces? Your best bet is to request a quantity spread, Eg: 1, 5, 10, 20, 50 and 100 parts.
[Edit to your edit] Does your drawing have a ton more detail? Simply saying 'close tolerances' or 'exactly' means absolutely nothing. Help us out here. If you are going to call out +/-.0002" on something, that will have a MASSIVE impact on pricing.
Old 05-24-2010, 04:58 PM
Well I think 1000 is too high, I'd like to get something under $800.
light production for now would mean 5, 10, 20, 50 and 100 pieces. but more immediate focus is getting a good prototype so I can market it and see if it fits and works the way I intend
Old 05-24-2010, 05:02 PM
i'm not sure what 4th axis means. I know what CNC machining is but have no idea any specifics. But one of the biggest problems the local guy told me that would cost the most is the curves on the outside in between the rails. He said because he doesn't have a tool for that curve it would cost the most to do that. He said that the cost of "fixturing" would be roughly $200 because of that special tool he would need for those curves.
Old 05-24-2010, 05:14 PM
well I have this drawing of what the specs need to be of the rails, the cross section and the grooves, it must be the exact specs given on these drawings or else my prototype will be useless. To be more specific it is a mil-standard 1913 "picatinny" rail which is a universal rail used to mount acessories like lights, lasers, etcs on firearms. If the specs are off on the rail the female part that slides over the rail and screw that fits into those grooves will not fit and my prototype will be useless and will need to re-machine another. And I dont' want that to happen cause i'm not a billionaire. Sorry for not being more specific in my first post. I apologize Matt, thanks for having the decency to help me fix
ID:	107804   Click image for larger version
Name:	pic rail cross section.png‎
ID:	107805   Click image for larger version
Name:	pic rail specs.jpg‎
Old 05-24-2010, 05:36 PM
I'm going to be right up front with you and let you know that your local guy doesn't know how to do prototypes. I'm not going to give away any of my knowledge on prototyping because my competitors are reading this, but I'd be happy to explain in private.
well I have this drawing of what the specs need to be of the rails...
Now we're getting somewhere. You have no need to worry, those tolerances are actually pretty loose, and any good machine shop will be able to make a part well within them.
Will you please send me your complete 2D drawing and solid model? matt_rfr@sbcglobal.net What is your time frame for the prototype?
Old 05-24-2010, 05:56 PM
please explain in private, sending an e-mail now. I don't have a time frame... just as soon as I get enough money to be honest with you. I'll send you the sketches I have and a 3d cad drawing thats slighlty different.. i need to change the cad drawing around because it doesnt have the taper and it has indents.. you'll see when i send it. Thanks.
Old 05-24-2010, 06:15 PM
mcphill is on a distinguished road
Does it have to be machined? I could give you a rapid prototype of this part for about $300. If you are interested, e-mail me at mike(at)mcpii(dot)com. If the prototype works out, I can source the machining, or give you pricing details on casting the part.
100% Made in USA suppliers.
Old 05-25-2010, 09:55 PM
Please note I found someone to do the prototype for me.
Old 05-27-2010, 02:20 PM
Excelmachine is on a distinguished road
If you go into mass production of these, you might want to check into getting an extrusion made. You could save a lot of machining time then. Extrusion dies aren't really that expensive. Just a thought.
  #11   Ban this user!
Old 05-27-2010, 10:50 PM
emily is on a distinguished road
International sales manager
Dear Sir,
I am Emily from Duch Group, one of the largest professional Mockup and Mould Company in China. I wrote to you before, Could you still remember me?
We based in Xiamen, with branches in Beijing and Suzhou, with 14 years' experience in this field, we provide full services like rapid prototyping, vacuum casting, tooling, low pressure perfusion, spray painting, silk screen, and laser engraving and so on.
The material we generally use in prototyping are Plastics(ABS,PC,PMMA,POM ,Nylon ect),Metal(Aluminum,steel ect.)
The size of model we can produce is from 300mm to 1mm.Besides, we work with ProE software, so the files of IGS, PRT or STP format are better.
Welcome to visit our website www.xmduch.com for more information.
If you are interested in our service, please feel free to contact me.
Thank you & best regards!
Emily
Skype: emily_mold
Tel: 0592-3862816
Fax: 0592-5972808
Address: 3rd floor, 1st building,Mingfa industry garden,Caitang,Xiamen city,China 361000
Another SMD prototype Jay C PCB milling 33 09-29-2009 12:30 PM
Need A Quote- Single unit prototype quote tjd10684 Employment Opportunity 6 07-17-2009 09:35 AM
Quote and Multi-Quote JoBwan Test Forum 0 02-23-2008 05:58 AM
RFQ quote /prototype Motorcoach1 Employment Opportunity 12 02-21-2008 12:35 PM
Quote Please Prototype Bluesman Employment Opportunity 2 07-04-2007 12:09 PM
