Go Back   CNCzone.com-The Largest Machinist Community on the net! > Employment Opportunity and RFQ (Request for Quote). > Employment Opportunity
Employment Opportunity Looking for a job in the machining field, need a employee in the CNC field post it here!
Old 05-17-2005, 01:15 AM
*Registered User*
coolman is on a distinguished road
RFQ: Skate Bearings
I designed these skate bearings in CAD. I need some aluminum 0.5" plates machined on an accurate CNC mill. The plate sizes (length & width) are exact measurements and need to be CNC milled to size. There are precise hole locations and sizes. The successful operation of these bearings relies on precise measurements which means it needs to be machined in a precise CNC mill. I just need quantity of 1 for now since I just want to test my design. If the design works, I will need upto 8 total. I already have the bearings and bolts.
For now, I just need a simple price quote. I am including a Zipped file that has the IGES Cad file.
Thanks,
ID:	7664   Click image for larger version
Old 05-17-2005, 08:13 AM
Gold Member
Ken_Shea is on a distinguished road
What is the "precise" requirement stated in + or - tolerances ?
Ken
Old 05-17-2005, 12:04 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Coolman
This http://www.mcmaster.com/ctlg/DisplCt...RelatedCtlgPgs will cost you a lot less money and aggravation. McMaster is not the least expensive place to buy from but they make a great all-in-one reference catalogue. They also ALWAYS (it's really unbelievable) deliver in less than 1 day (remember I am across border as well).
www.integratedmechanical.ca
Old 05-17-2005, 07:20 PM
georgebarr is on a distinguished road
Ken Shea,
The precision I need for the parts is atleast 0.005".
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
ABEC Skate Bearings andy_ck87028 Mechanical Calculations/Engineering Design 3 01-26-2005 07:07 AM
Newbie saying hello & a tip on using skate board bearings DJ Morrow DIY-CNC Router Table Machines 4 12-30-2003 06:27 PM
A question on bearings......to skate or not to skate HiString DIY-CNC Router Table Machines 1 11-12-2003 01:46 AM
Roller Skate Bearings? ljoe1969 DIY-CNC Router Table Machines 11 11-09-2003 06:46 AM
